Old 02-26-2022, 11:24 AM   #1
Sovereign
Mild Tubz and 275/40/20s
Hi All,
I have an 86 C10 that I've lowered 4.5" in the front. I'm wanting to go with mild Slosh Tubz so I can have more suspension travel. Does anyone know if 275/40/20s will have any issues clearing the tubz? Rims are your typical 20x8 with 0 offset. I see most people have 245/40/20s for tires on the front. I bought the truck with these tires and rims and would really like to keep them as I prefer slightly thicker sidewalls.
While we're talking wheel size, anyone know what the widest rim and tire combo is with mild tubz should I decide to replace what I have in the future?
Thank you
Sovereign is offline   Reply With Quote
Old 02-27-2022, 07:24 AM   #2
TrybalRage
Re: Mild Tubz and 275/40/20s
Originally Posted by Sovereign View Post
Hi All,
Thank you
I don't know that many people have them. I haven't even seen many good pics of the inside of the wheelwell to show the difference inside (are they taller, wider, both?). I just visited their website and for our trucks it doesn't look like they list those details. Might be worth reaching out to them.
1985 C10 Silverado LWB LS Swapped! Other Stuff
2010 Suburban 2500 LT 4WD
YouTube
TrybalRage is offline   Reply With Quote
Old 02-27-2022, 12:17 PM   #3
Big Chip
Big Chip's Avatar
The tub goes up a couple inches just inside the fender lip. You have to cut your fender structure to install them though. If you are just hitting when the suspension bottoms out and not when you turn the wheel the slosh tubz should work.
Big Chip is offline   Reply With Quote
Old 02-27-2022, 04:22 PM   #4
Sovereign
Yes, I'm aware I have to cut the fenders. That's not a problem. I thought the mild tubz were also wider overall going into the engine bay further? It certainly looks that way when viewed on their website.
I barely scrape when turning and only under certain conditions. I haven't had time to drive the truck much to determine exactly where I scrape when turning aside from on the inside of the passenger side. Suspension compression is the biggest reason I'm interested in tubz. I'm riding on the bump stops now and that's no fun.
Thank you.
Old 02-27-2022, 05:21 PM   #5
Big Chip
Big Chip's Avatar
They are wider. I don't have mine installed yet but they look like they go almost to the frame.
Old 02-27-2022, 10:24 PM   #6
Sovereign
Thanks! I'll try to get mine ordered soon. No idea when I'll finally get them in though.
