Old 02-27-2022, 10:39 AM   #1
KDogApache59
KDogApache59's Avatar
Parking brake components needed
Looking for a set of parking brake levers and struts for a 67 truck rear end. Anyone have anything off a parks rig or know of a source? Thanks in advance.
KDogApache59 is offline   Reply With Quote
Old 02-27-2022, 11:09 AM   #2
Accelo
Accelo's Avatar
Re: Parking brake components needed
Do you mean the levers that are attached to the cross member?
What are struts in 67? Are they part of the levers on the cross-member?
Accelo is offline   Reply With Quote
Old 02-27-2022, 11:22 AM   #3
Grumpy old man
Grumpy old man's Avatar
ROCKAUTO
https://www.rockauto.com/en/catalog/...ke+strut,10715
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 02-27-2022, 07:11 PM   #4
KDogApache59
Hoping someone did a disc brake swap on the rear and had the parts I need.
Parking brake lever left hand side; PN GM 15594177 is available from different vendors. Right hand side is PN GM 15594178 and is discontinued. These levers attach to the primary brake shoe and connect to the parking brake cable. Struts and springs I can get from current vendors as well (thanks Grumpy). They sit between the secondary brake shoe and the parking brake lever.
The only part I can't source is the right hand brake lever but figured that if someone had that piece they likely had the rest as well. Going to check my local salvage yards this week but though I might wander onto what I need here first.
Tried to attach a photo link below, don't think it works.
KT
