Old 02-27-2022, 03:19 PM   #1
HwyStarJoe
HwyStarJoe's Avatar
'Sport Mirror' question...
Hey all... I think I know the answer already...
Are the 'sport mirror' arms adjustable at all up or down? Do they rotate in the base? I'd like to raise mine a bit. That is if I can ever get them off. I've broken three #3 bits on the screws already. 53 years has them not wanting to come out even though they're not rusted, and have been lubed like crazy.
HwyStarJoe is offline   Reply With Quote
Old 02-27-2022, 07:00 PM   #2
pjmoreland
pjmoreland's Avatar
Re: 'Sport Mirror' question...
The tubular arm is welded to the base, so it would take some fabrication work to adjust them higher. If you've got the small round mirrors on them, another option might be to go with the larger rectangular mirrors.
https://www.classicparts.com/mobile/...ctinfo/58-204/
pjmoreland is offline   Reply With Quote
Old 02-27-2022, 07:16 PM   #3
HwyStarJoe
HwyStarJoe's Avatar
Figures they're permanent. I've got the 5x7's... I just want to raise them a tad.
If I could get them off the door I have no problem zinging the spot welds and rewelding them.
Oh well... on to something else.
Old 02-28-2022, 02:17 PM   #4
HO455
HO455's Avatar
Permanent is relative. The passenger side of mine was loose and after removing it I found that there were only 2 small tack welds securing the base to the arm and they were both broken. I cleaned the welds up with a Dremel and re-tacked the 2 pieces how I wanted them.
I can't guarantee all of them have only two small tack welds but it it's worth a look to see. Then some careful grinding, realignment, and some new welds should get you what you want.
RIP Bob Parks.
Old 02-28-2022, 07:23 PM   #5
HwyStarJoe
HwyStarJoe's Avatar
I still can't get them off the doors. Dissimilar metals between the screws and the nuts inside the door are giving me hell.
I tried forcing the arms without breaking anything and they're welded up tighter than a battleships hull.
Just gonna have to live with it.
Old 03-01-2022, 02:06 AM   #6
custom10nut
custom10nut's Avatar
Have you tried a 1/4 inch drive, battery powered impact wrench?
Spray it with your favorite penetrating oil, from the back side, then hit it with the Impact
Set it on the low torque setting to just kinda hammer it out.
I’m really kinda surprised your breaking tips and bout stripping out the screw.
custom10nut is offline   Reply With Quote
Old 03-01-2022, 02:21 AM   #7
Accelo
Accelo's Avatar
custom10nut has given good advice. Be sure to use the larger Philips head in your gun. Too small a bit will break off quickly.
If all else fails drill off the heads of the screws. The mirror backing plate will fall to the bottom of the door. Then you can use a grinder to clean off the remnants of the screw head and vise grips to back them out. Use the vise grips on the long rusty threaded end. Only 1/4" of bolt to back through the nut that way. Only draw back is you will need new screws. A little grease on the threads will keep the rust out.
Same technique can be used on the lower inner door panel screws.
Accelo is offline   Reply With Quote
Old 03-02-2022, 02:41 PM   #8
71gmcC15
71gmcC15's Avatar
Fun fact I noticed about the mirrors. Bases. Thare the same left and right. Even the arm. They just rotated the arm around for each side. Gm and thare lazy buts.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 03-02-2022, 05:35 PM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
I believe the passenger side arm is slightly longer than the drivers side.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 03-02-2022, 09:47 PM   #10
LockDoc
The Older Generation
LockDoc's Avatar
This is true. It is to get past the wing window bar.
LockDoc
Leon
Old 03-03-2022, 12:01 PM   #11
71gmcC15
71gmcC15's Avatar
Looks like I'm getting the tape measure out.
