Old 02-27-2022, 09:33 PM   #1
Bushman66
1971 Power steering hose routing and connections pic requested
Hi all,
I have a 1966 C10 that I just converted to power steering using Captain Fab's bracket. I have a 350, short water pump, and the Alan Grove Power steering bracket that mounts the pump on the driver's side, below the alternator.
I used a 71 steering box and a 71 pump. Assuming that the 71 had the same mounting arrangement, I'm assuming that factory hoses will work (probably have to trim the lower lip of the inner fender slightly).
Does anyone have some pictures of a 70-72 power steering setup that shows the routing of the hoses? I assume that the high pressure line connects to the port that is slightly forward and offset to the passenger side?
Thanks!
Bushman66 is offline   Reply With Quote
Old 02-27-2022, 09:58 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: 1971 Power steering hose routing and connections pic requested
I used the 71-72 alt bracket and PS pump bracket on my 350 ,short water pump , Stainless Hoses are from Member Pickmup . I polished the hoses and Summit carries a Stainless hose bracket to mount the hoses to the frame similar to the stock bracket .This is a 67 stock frame.
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 02-27-2022, 10:03 PM   #3
Grumpy old man
Pic .
Old 02-27-2022, 11:25 PM   #4
Bushman66
Thank you!
Old 02-28-2022, 01:33 AM   #5
FirstOwner69
FirstOwner69's Avatar
I think the 70/72 would be the same as my '69.
Jim
FirstOwner69 is offline   Reply With Quote
Old 02-28-2022, 03:10 AM   #6
Accelo
Accelo's Avatar
Anyone know who sells he frame bracket that retains the P/S tubing?
Accelo is offline   Reply With Quote
Old 02-28-2022, 09:21 AM   #7
Grumpy old man
This is the one I found at summit , it's just a double zinc 3/8 line clamp , It worked fine .
https://www.summitracing.com/parts/rsd-rsclp44
