Old 03-02-2022, 03:56 AM   #1
HOGDADDY
HOGDADDY's Avatar
New Speedhut gauges
Finally, gonna get some real gauges. Installing them in OEM pod & bezel.
GPS speedo to boot.
So far so good!
HOGDADDY is offline   Reply With Quote
Old 03-02-2022, 08:48 AM   #2
Ziegelsteinfaust
Re: New Speedhut gauges
Looking good.
Do they pop right in and the factory plug works?
Or did you have to rewire them?
Ziegelsteinfaust is offline   Reply With Quote
Old 03-02-2022, 10:11 AM   #3
HOGDADDY
HOGDADDY's Avatar
Originally Posted by Ziegelsteinfaust View Post
Looking good.
No, I had to enlarge the holes and will need to re-wire.
I used the metal pod from an earlier model truck.
I did this below only used different gauges.
https://www.youtube.com/watch?v=-SMI4H35ASI&t=3s
Old 03-04-2022, 02:45 PM   #4
Hart_Rod
Hart_Rod's Avatar
Those look really good! What was the price?
Hart_Rod is offline   Reply With Quote
Old 03-05-2022, 12:15 PM   #5
HOGDADDY
HOGDADDY's Avatar
I just bought individual gauges from Speedhut and installed them in the oem pod. They are made to order and you can get some customization if you like. I opted for none.
Their prices are listed on website and the speedo includes GPS receiver. Around 1k pricewise. Lifetime guarantee!
Old 03-05-2022, 05:08 PM   #6
Axle
Axle's Avatar
Nice clean look.
Thanks a lot for adding something else to my list...
Axle is offline   Reply With Quote
Old 08-27-2022, 08:51 PM   #7
HOGDADDY
HOGDADDY's Avatar
OK I think I am finally getting about done with fitting the Speedhut gauges in stock locations.
After taking a new $$ aftermarket gauge panel and carefully cutting and filing down the gauge holes on the backside so they would fit flush, it is looking ok.
Here is a picture.
Hard to tell from pic but they are sitting in the stock green gauge pod along with a metal piece pictured above that I painted black.
It will attach like factory gauges using stock screws.
The wiring harness that comes with kit allows up to 8 to be connected together which is nice!
Old 08-27-2022, 09:09 PM   #8
HOGDADDY
HOGDADDY's Avatar
Also thinking about putting these in stock turn signal holes along with a brake and idiot alt light so it will charge properly. (I am aware of doing it with resistor also)
Speed hut has turn signals in speedo so I am still on the fence.
Of course, for the brake and alt I would have to drill small holes in gauge panel.
These are Alpinetech indicators and they would look nice in stock turn signal locations.
I test fitted them in an old panel and recessed them like stock after drilling out the inside but attaching them securely is another issue I am trying to figure out.
Old 08-30-2022, 06:43 AM   #9
Corts60
Just here to tinker
Corts60's Avatar
Those alpine tech indicators would look great in my opinion.
Nice job on fitting the gauges!
Old 08-31-2022, 07:04 AM   #10
52napco
Had the Speedhut gauges in my 280Z with a LS1 and T56 and they worked great for years
52napco is offline   Reply With Quote
Old 08-31-2022, 10:10 AM   #11
blazer2007
I thought a GPS speedo would be good for me and maybe a matching tach until I looked at the price. 450.00 just for a speedo, that,s about 800.00 Canadian by he time I get it here. Guess I will stick with what I have.
blazer2007 is offline   Reply With Quote
Old 08-31-2022, 05:14 PM   #12
HOGDADDY
HOGDADDY's Avatar
To be fair, other manufacturers (Autometer for one) do not include the GPS module. They charge $240 just for the module alone.
Old 09-03-2022, 07:13 PM   #13
HOGDADDY
HOGDADDY's Avatar
Can't wait to install these along with my NOS dash pad courtesy of Captkaos from many years ago. It's still in the box.
I thought $500 (or was it 400? I forgot) was a lot then, but my have the prices jumped since.
Old 09-04-2022, 08:21 PM   #14
GSP7
GSP7's Avatar
160 mph ...Wow !
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is offline   Reply With Quote
Old 09-06-2022, 12:09 AM   #15
HOGDADDY
HOGDADDY's Avatar
Originally Posted by GSP7 View Post
160 mph ...Wow !
Stock was 85 mph which was too low to begin with and although I don't plan on ever doing 160, it's nice to have that option for later or if I move to Germany.
