03-02-2022, 08:26 AM | #1 |
Cab and Door measurements
Good Morning
1966 Chevy C10 Back of cab has been pushed in, think i can fix that issue Doors seem to be really hard to get right, drivers door doesnt want to latch Passenger does latch, but raises a little on latch Does anyone have inner door measurements on cab Trying to see if cab has been twisted Thank's Jeff
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything |
03-04-2022, 10:57 PM | #2 |
Re: Cab and Door measurements
anyone, Thank You
03-04-2022, 11:20 PM | #3 |
I don't have the measurements, but do have a question for ya. Are the door hinges in good shape? I had a heck of a time slamming my doors closed before I put some new hinge pins and bushings in. That made closing the doors much easier than before. I mention it because you said the passenger door raises on the latch. Another possibility is that once you have good door hinges, you might need to replace the latch components as well
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
03-05-2022, 02:55 AM | #4 |
i am going to replace the hinge pins and bushings, have you used the ones from Oreillys or do i need to order from another source,
doors still both seem to need to go back towards the back of cab, very wide and scraping the front slightly Thanks
03-05-2022, 12:47 PM | #5 |
I used ones from the typical aftermarket resellers, but if the ones sold at Oreillys is the correct part, you should be fine. I had to pull the hinges completely off the truck and doors to replace the pins. I needed a big hammer and a cut off wheel
The doors can be adjusted in two directions. The hinge plate on the door side allow the door to move in and out with relation to the cab. The hinge plate on the cab side allows the door to move forward and backwards so you can center the door in the opening.
03-19-2022, 02:36 PM | #6 |
Good Afternoon
Quick update, the Po welded the rockers in about 1/4 inch too high so adjusting my doors are not going to be close until the rockers are replaced, ive got new ones , waiting on the weather to stay warm Does anyone have a front and back door measurement from the top (drip rail, maybe ?)somewhere to where the rocker sits i know now if the rockers are off the cab corners are probably off also i can fix and adjust but having a reference measurement would at least give me something to start with Thanks for any Help
