Old 03-02-2022, 03:05 PM   #1
PbFut
Oil Pan Clearance Question
Is there sufficient room to pull the oil pan on a 72 C20 OEM SBC or does the engine require lifting to provide clearance?
I always get nervous moving large parts for fear it won't drop back into correct position laying on my back pissed off and using language unbecoming.
I searched an hour and did not find a definitive answer. Likely right in front of me, but new here so have some patients please.
Prepping for RMS replacement.
Thanks in advance.
PbFut is offline   Reply With Quote
Old 03-02-2022, 03:40 PM   #2
C101972
Re: Oil Pan Clearance Question
There is, Turn the motor over so that the mark on the balancer is to the bottom “ or 6 o’clock “. take the long motor mount bolts out “one on each side”. If you have a cherry picker, lift the motor up high enough to put the motor mount bolts back in on top of the existing mount of the frame, if you don’t have a cherry picker you can use a floor jack “carefully jacking up on the balancer”. When the balancer is at 6’oclck all the journals are up in the block and the oil pan can be removed. Thanks Chuck
C101972 is offline   Reply With Quote
Old 03-02-2022, 06:16 PM   #3
PbFut
Thank you sir.
I was hoping not to have to unbolt the mounts. Getting the mount bolts to realign is always my fear. Suspected it was needed. Parts just ordered. Should be able to fit the project in next week.
Old 03-02-2022, 10:50 PM   #4
pjmoreland
pjmoreland's Avatar
If you loosen the bolts that attach the engine stands to the frame and cross member, then it will be much easier to get the motor mount bolts to align when reinstalling them.
pjmoreland is offline   Reply With Quote
Old 03-03-2022, 10:51 AM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-03-2022, 11:58 AM   #6
C101972
If you use a block of wood and jack up on the balancer you will have no problems, have done it many a times. Or just take a little more time and pull the motor out and do your repairs on engine stand.
Old 03-04-2022, 02:02 PM   #7
MARKDTN
'72 should have the clamshell mounts. Much easier IMHO to line back up than the earlier style.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
