Old 12-30-2003, 12:12 PM   #1
terrym1
terrym1's Avatar
welding valve covers
First off can j&b keep the valve cover from leaking? second can this be welded. I know it is hard to see the crack but it is on one side of the bolt hole and the bottom of the pan is bent. I don't want to throw the pan away because the other one is good. just want to fix it right. You guys have any sugestions please let me know. terrym1
p.s. some one else put the J&B on it not me I got it this way.
terrym1 is offline   Reply With Quote
Old 12-30-2003, 12:24 PM   #2
terrym1
terrym1's Avatar
2
second
Old 12-30-2003, 12:34 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
JB Weld will absolutely fix a crack in an aluminum valve cover.
Whether it re-cracks because it's warped or not is another matter.....
You could also have it Heli-Arced too.
Old 12-30-2003, 01:37 PM   #4
PR454SS
PR454SS's Avatar
Don't remember what it is called but I got some stuff at the last Pigeon Forge show that allows you to fix aluminum with a torch and a special rod, almost like tig welding but it is not really welding, you just kinda heat it with a propane torch and then feed the rod into the needed repair in a circle, I used it to repair some stuff I had, worked real well.
PR Too many projects, not enough time!
72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold!
69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam.
78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's
77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs
PR454SS is offline   Reply With Quote
Old 12-30-2003, 01:57 PM   #5
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Go to a welding shop and ask them to fix it for you. Easy 5 min weld would fix it better than JB weld.
67Fleetsidedream is offline   Reply With Quote
Old 12-30-2003, 02:06 PM   #6
fatfords
fatfords's Avatar
Like TXFirefighter said, the JB weld will work fine. You might consider also using a set of the valve cover clamps to spread the load away from the fastener hole.
Good Luck!
'56 F-100 (w/all GM stuff)
Lookin' for another parts chaser!
'05 GMC crew cab
fatfords is offline   Reply With Quote
Old 12-30-2003, 02:34 PM   #7
terrym1
terrym1's Avatar
thanks
thanks for all your help with this problem great suggestions. This is no doubt a great board
Old 12-30-2003, 08:52 PM   #8
neonlarry
neonlarry's Avatar
I cant see the crack real well, but I dont think it would be that hard to tig weld it.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 12-31-2003, 10:35 AM   #9
cag17
cag17's Avatar
I think that you are referring to hemrod. I saw it at Hillsville and Charlotte. I am trying to find a retailer for it now. Could you send me some info on it.
Bowtie Club of the Carolinas
cag17 is offline   Reply With Quote
Old 12-31-2003, 11:21 AM   #10
terrym1
terrym1's Avatar
thanks cag17 that would be helpful
terrym1
Old 12-31-2003, 03:26 PM   #11
cag17
cag17's Avatar
If any of you are into welding you have to see one of these. I know that it isn't the same as welding but I watched a guy use it on an aluminum can. It was amazing
Old 12-31-2003, 03:59 PM   #12
PR454SS
PR454SS's Avatar
Ya that's the stuff I got at the show, He would punch a hole in the can and then repair it. It is called Aluminum repair rod and there is a telephone number 1-800-822-6935
Old 12-31-2003, 04:36 PM   #13
charles oliver
68 camtruck
charles oliver's Avatar
Repairing Aluminum
The rod used in above message to fix aluminum is called
Dura-Fix
www.durafix.com
I purchased some but haven't used it yet. Worked pretty neat at a car show. He even showed repairing an Aluminum Valve cover..Good Luck
Charlie
71 GMC Jimmy 4X4
68 Huger Orange Camaro 454 with TH400 :gmc
charles oliver is offline   Reply With Quote
Old 01-05-2004, 12:07 AM   #14
1972C10
1972C10's Avatar
If you have a wire feed welder or acess to one you can weld it with it just have to have 100% argon and alum welding wire
1972C10 is offline   Reply With Quote
