Old 12-30-2003, 01:13 PM   #1
chargedstang89
Installing WARN Manual Hubs..any tips??
I got some WARN premium hubs for Christmas, and I was wondering if anyone has any helpful tips on getting these bad boys installed easily? Any tricks, or links to websites with instructrions?
chargedstang89 is offline   Reply With Quote
Old 12-30-2003, 10:08 PM   #2
Cethern
What was I thinking??
Cethern's Avatar
I'll tell you what we'll put them on my Blazer first ok? that way you can see how easy it is so when you get a newer set as the ones you had would be used and you wouldn't want a used set of hubs right? :p
Really it's not hard you will need a allen wrench and some snap ring pliers. after you take off the old set (I'm guessing there is a old set) you take the six allen bolts out and the is a snap ring around the outer edge of the hub it's sometimes to see you can get it off with a flat blade. then there is a smaller snapring on the axel after you get that off the hub will come out/off. and the new set will go on the same way.
I hope this helps and made some sence
Cethern
Oh if you have a good manual it should have a brake down of the hub
Cethern is offline   Reply With Quote
