Old 03-06-2022, 09:14 AM   #1
mm1077
Active Member
mm1077's Avatar
Door interchange?
I have a good passenger door shell from a 72 and wondering if it will work on my 67 (before I remove/disassemble the 67 door from the truck). I’ve read the 72 doors are different? Thanks!
mm1077 is offline   Reply With Quote
Old 03-06-2022, 10:04 AM   #2
Getter-Done
Getter-Done's Avatar
Re: Door interchange?
The outside door handle is different from 72 to the (67 only handle).
Also, the 72 has a screw on the inside below the turn knob for the vent window for extra support.
Here are a couple of links also.
Link: https://67-72chevytrucks.com/vboard/...oor+difference
The early bird gets the worm,
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 03-06-2022, 10:12 AM   #3
mm1077
Active Member
mm1077's Avatar
Thank you, that first link answers what I needed to know. Looks like I can use the 72 door and still use the metal door panels. I need a new regulator anyways and already purchased new door handles.
Old 03-06-2022, 10:25 AM   #4
Getter-Done
84 Chevy K-20
