Old 03-06-2022, 07:19 PM   #1
zacharywest34
zacharywest34's Avatar
63 k10 power brake booster
I am wondering if anyone has info on what conversion for 1963 K10 drum drum power brake booster and master cylinder would work best. Motor is a pretty much stock 350. Which kit did you use.
1971 C20 350sbc mild cam
Daily driver
zacharywest34 is offline   Reply With Quote
Old 03-06-2022, 07:52 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: 63 k10 power brake booster
You can use the booster bracket made by member Captainfab: https://67-72chevytrucks.com/vboard/...d.php?t=339081
For the master, I'm not exactly sure what works best on the 4wd trucks, but maybe a dual master from a 67-70 4wd would work?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 03-10-2022, 10:07 PM   #3
Captainfab
60-66 Nut
Thank you Christian
With one of my booster brackets I would recommend a '67-'70 booster and master cylinder for a drum/drum braking system.
Old 03-10-2022, 11:18 PM   #4
Tonyprieto
Captn does he have to get a different brake push rod? or just your bracket and a booster?..Thanks!
Tonyprieto is offline   Reply With Quote
