Old 03-07-2022, 10:29 AM   #1
44SAA
What is this? ‘80 C20
Howdy- can you fellas put eyes on this and help me ID please? It’s driver side located in front of cruise. It’s grounded and not mounted to anything, just flopping around. Thank y’all
44SAA is offline   Reply With Quote
Old 03-07-2022, 12:23 PM   #2
kwmech
Re: What is this? ‘80 C20
Looks like an AC relay. but it's in the wrong spot. find out where the red wires go. Obviously one will go to battery the other???
Old 03-07-2022, 12:34 PM   #3
mongocanfly
mongocanfly's Avatar
Does look like it..
https://www.classicindustries.com/product/d158168.html
Might unplug it and see if theres any numbers stamped into it
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-07-2022, 12:43 PM   #4
44SAA
Yeah- looks identical to my AC relay. Here is what it connects to. Thank you fellas. Old boy had a CB hooked up, maybe that’s what it was for
Old 03-07-2022, 12:47 PM   #5
44SAA
Yeah Mongo- same part. However, my AC and blower relay on pass side are all squared away and working.I think it may have something to do with emissions canisters I removed as they were in the same area
Old 03-07-2022, 03:33 PM   #6
sick472
sick472's Avatar
Horn Relay...Maybe??? Easy enough to test for that.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 03-07-2022, 04:52 PM   #7
Dead Parrot
Possible a PO salvaged that relay from a different vehicle and used it for some gizmo in the truck.
Pull the connector loose and see what, if anything, quits working.
Possible the gizmo was pulled from the truck before it was sold.
Dead Parrot is offline   Reply With Quote
Old 03-07-2022, 05:49 PM   #8
Wgesnerjr
Wgesnerjr's Avatar
I saw this on a C20 Camper Special we once had. I think it was for the dual battery set up for the camper. I think the relay isolated the battery when the truck was off and charged it when the truck was running. Ours was pretty FUBARed when we got so not 100% sure on its true functionality from the factory. Just my guess.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 03-07-2022, 06:27 PM   #9
44SAA
Thanks Jay- I have a trailering special and PO removed battery tray. You may be onto something
Old 03-07-2022, 08:23 PM   #10
temp190
Is this it?
temp190 is offline   Reply With Quote
Old 03-07-2022, 08:55 PM   #11
44SAA
Thanks fellas- couldn’t have figured it out myself. Here is a pic including my sidekick fishing partner/assistant wrench turner
Old 03-07-2022, 09:12 PM   #12
Corts60
Just here to tinker
Corts60's Avatar
That’s also the same relay GM used for the glow plugs on the early diesels. 78-80 they mounted two of them on the driver side fender. One relay for each bank of glow plugs.
Old 03-09-2022, 06:35 PM   #13
LT7A
Nice looking truck. And boots, shorts, and shades - your sidekick is ready for anything.
