Old 03-07-2022, 09:04 PM   #1
Reno
Reno's Avatar
Fuel Problems
ok not sure I'm in the correct sub group but here goes
I recently purchased a 1988 V30 Cab & Chassis 1 ton 4x4 Pickup with SBC & 4 speed - this is the traditional square body cab
Truck had set for awhile after having new crate motor installed. Now previous owner had gas tank & lines flushed, new plugs & wires are present
Truck starts and runs down the road but after short while its like the fuel line is collapsed or plugged. I also checked the fuel filter & it seems fine. It has dual tanks and have replaced the electronic tank switch. Has Eldelbroc carb on engine....
What would you check replace?
Restomod 1970 2WD Blazer LT4
Custom 1968 Suburban Cummins
Reno is offline   Reply With Quote
Old 03-07-2022, 09:11 PM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: Fuel Problems
If it’s been sitting with any type of ethanol mixed fuel, it could’ve deteriorated the rubber lines. Just a thought.
Old 03-07-2022, 10:37 PM   #3
Ziegelsteinfaust
Re: Fuel Problems
My thoughts too.
E10 or E15 is very common these days. It softens cheap ornolder hoses pretty good. Which can cause them to swell it collapse.
Ziegelsteinfaust is offline   Reply With Quote
Old 03-07-2022, 11:18 PM   #4
Dead Parrot
Re: Fuel Problems
Check the suction lines from the tanks to the switch valve. Often overlooked and if original, probably crumbling away and allowing air in, breaking the suction.
If it had a charcoal canister that was removed, possible the PO plugged the vent hose. Without a vent, the tanks will eventually stop letting gas out.
Dead Parrot is offline   Reply With Quote
Old 03-08-2022, 12:03 AM   #5
3drburb
Re: Fuel Problems
If you don't have a fuel pressure regulator that may be your problem. To much or to little fuel will sometime do this with the Edelbrock carbs. 5.5 psi should be a good starting point and go plus or minus from there.
3drburb is offline   Reply With Quote
Old 03-08-2022, 01:21 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Fuel Problems
i dont know how old the carb is but i recently went through three carbs that were brand new Edelbrock 1406 carbs sealed in boxes that had all kinds of crud in them.. the floats were bad and there was a black gunk in the bowl these all came from advance Auto Parts
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
