Old 03-08-2022, 09:05 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
A/C compressor - Seeking Edgeucation
I'm working on a rebuilt original A/C system, getting ready for a maiden start soon. I have all the connections figured out, o-rings and such. I'm leaving the connections snug only for a pro to tighten things up.
I'm wondering if it's A-ok to connect the compressor belt so long as the A/C isn't run? It will be charged with R134A after the truck is running.
I've never tensioned an A/C belt before. Near as I can tell I can do that with a pry bar against the compressor and its lower bracket, but is there a cleaner way to accomplish this?
Thank you
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
