Old 03-10-2022, 08:21 PM   #1
cj847
cj847's Avatar
1969 instrument cluster in a 1967
Every time I drive my 67, I pull the darn wiper knob off thinking it's the headlight (my other truck is a 71).
Anyway, I would like to put a 69 and up instrument cluster in (or at least the outer cover). The wiring is not a problem, but the light switch mounting hole is. The upper hole (currently for wipers) is 1/2" dia with a flat across (same as choke). The headlight switch hole is 7/16" with a notch to keep the switch in proper position.
I plan to just hack a slot in the bottom of the 1/2" hole and drill enough of the flat off to get it perfectly centered in the instrument panel. Just checking for better ideas from someone who's done it.
PS> the 3 holes other than the headlight hole are all the same shape
cj847 is offline   Reply With Quote
Old 03-11-2022, 01:02 AM   #2
pjmoreland
pjmoreland's Avatar
Re: 1969 instrument cluster in a 1967
I replaced the dash in my '68 with one from a newer truck, so I had to modify the holes in the opposite direction you are planning on doing. I just used small jewelers files to open up the one hole and to create the slot in the other one. It didn't take very long to do.
pjmoreland is offline   Reply With Quote
Old 03-11-2022, 10:30 AM   #3
C101968
I have a 67 gauge and bezel available if needed.
C101968 is offline   Reply With Quote
