03-12-2022, 11:03 AM | #1 |
Leaf spring sliders
I saw Roadkill Garage, and they put then on the Vanishing paint Challenger.
Are they good for a truck that only will haul around on stuff of the weekends? Or are the not set up for the pounding, and weight factor. Even if I accept all the bearing or bushing replacements they will entail. |
03-15-2022, 09:36 AM | #2 |
Re: Leaf spring sliders
The chryslers use a short shackle on the rear of the leaf spring and they tend to bind up under power. If you put super stock springs or other performance springs with a different rate you run out of shackle length and thats where the sliders came to be on the chryslers. It allows the spring to travel back as the arc comes out of the spring smoothly and with out bind to keep the car planted better. I have not seen one of our trucks run into spring bind at the shackle and really dont think the chrysler ones are intended for use under a truck.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
03-16-2022, 09:06 PM | #3 |
A number of years ago I mini-tubbed a 67 Nova. I thought the offset shackles looked a little weird. The local dirt track stock car chassis builder talked me into the sliders and they worked great. I forget which springs I used. I did use his double adjustable shocks. I had drove the car for about 4 years and then sold it to make room for a new project.
Can't speak to the load capability. That will depend on the rear springs. |
03-20-2022, 05:56 PM | #4 |
At the body shop.
Matt Funkhauser makes a nice slider.
Leaf spring Nation of Facebook
" That didnt make it any newer " " Dont antique the equipment " |
