Old 03-13-2022, 02:54 PM   #1
Rusty trucker
No power to the fuel pump
My 97 Chevy K1500 with a 5.7 lost power to the fuel pump driving down the road. All the fuses are good.
Rusty trucker is offline   Reply With Quote
Old 03-13-2022, 02:57 PM   #2
Just call me Sean
Just call me Sean's Avatar
Re: No power to the fuel pump
Is there power to the relay?
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 03-13-2022, 03:06 PM   #3
Rusty trucker
yes, I do have power at the relay
Old 03-13-2022, 03:34 PM   #4
Could be oil pressure switch. Can you jump power direct to the pump off the battery (or other)?
Old 03-13-2022, 03:50 PM   #5
Just call me Sean
Could try swapping the relay with another in the box and see if it's bad. Definitely check codes, the cam or crank sensor could be bad so the computer doesn't see the engine cranking. Oil pressure switch is a possibility too as mentioned.
Old 03-13-2022, 03:56 PM   #6
Rusty trucker
I just was messing with the relay checking for power and ground, now I have power to the pump. Starts right up. Will be ordering a new relay tomorrow. Where do I find the oil pressure switch on the motor? Might change that as well just to be on the safe side with 170000 miles on it
Old 03-19-2022, 01:20 PM   #7
Rusty trucker
replaced the fuel pump relay and the oil pressure switch and so far so good
Old 03-19-2022, 02:55 PM   #8
Good to hear. Where is the OPS, back of intake area? I only worked on diesels and that's whare they are (D/S)
Old 03-19-2022, 07:20 PM   #9
Rusty trucker
Yes, just below the distributor
