Old 03-13-2022, 06:59 PM   #1
Peanut74
Steering Box Rebuild Question
Ok, I am in the middle of rebuilding my steering gear box. I am at the point to where I am placing the ball bearings in the gear box. I placed all twenty-two 0.280" diameter bearings in worm gear drive and can see now see them on both sides. However, I don't have anymore bearings to put in. What am I missing here?
When I took it apart I made sure to account for all the bearings that came out.
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 03-13-2022, 07:57 PM   #2
Accelo
Accelo's Avatar
Re: Steering Box Rebuild Question
I have found some Saginaw that used 22 ball bearings, instead of the more common 24.
If you every have taken apart a steering column GM didn't completely fill the void there either.
Accelo is offline   Reply With Quote
Old 03-14-2022, 07:26 AM   #3
Peanut74
Thanks Accelo. I figured out that some of the bearings went the wrong direction. Turns out I needed to move the worm drive to make sure they went in in the correct direction. Even then I had a bit of a void. But it is back together.
Old 03-16-2022, 09:00 PM   #4
Peanut74
Well I got steering box on the truck and lines connected. Fired it up and no leaks found. So glad to finally have the leaks fixed.
