Old 03-15-2022, 10:03 AM   #1
67ss&99ss
Andy
Axle Swap Question
I have a 69 C10 that I want to convert to 5 lug. I have a pair of 71-72 5 lug axles and drums that I would like to use. Can these axles be used in the 69 housing if I have some spacers machined to go between the housing flange and backing plate to compensate for the longer 71-72 axle? I can get a sheet of aluminum for 30 bucks from McMaster Carr and have the machine work done by a friend for a case of beer most likely. If this would work it's way more cost effective than buying conversion axles.
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi
1969 CST/10 383|Aisin AR5 5 speed
1972 K5 LT1|Turbo 350 4x4
2005 Duramax 2500HD 4x4
67ss&99ss is offline   Reply With Quote
