Old 03-15-2022, 10:46 AM   #1
Thealien
Thealien's Avatar
WTB Oil fill tube bolt.
As the title states I’m looking for a factory bolt that bolts through the manifold and has a stud sticking up for mounting the oil fill tube.
Mark
Old 03-15-2022, 12:19 PM   #2
Ironhorse
Ironhorse's Avatar
Re: WTB Oil fill tube bolt.
I have several stud bolts but not sure what the needed thread and bolt depth would be. If you can supply thread size and grip length of the bolt I can check my stud bolts to see if any are correct for you need.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 03-15-2022, 04:06 PM   #3
Thealien
Thealien's Avatar
Since I don’t have one I cannot offer that information. But I’m sure someone here will speak up if they see this.
Mark
Old 03-15-2022, 05:25 PM   #4
Ironhorse
Ironhorse's Avatar
Mark, sorry can't be more helpful with the correct stud bolt your looking for. I have about half a dozen of various sizes which '' might " be correct but have no information for the needed size. Hopefully someone can chime in here with the right size your needing.
Wellington, Ks
Old 03-15-2022, 10:16 PM   #5
TxGary
TxGary's Avatar
Mark: here is pic. of the one on my 71. 3/8" bolt, 15/8" long, 1/4" spacer, flat washer, lock washer. Hope this helps you.
71 C-10 SWB
1969 C-30 Custom Camper Motorhome Restoration in progress.
2020 Chevy 2500 Crew 4x4 LTZ Diesel
2024 Chevy Tahoe Z71 4X4
2015 Diamond C 22' HD car hauler
Bowie, Texas 76230
TxGary is offline   Reply With Quote
Old 03-16-2022, 05:49 AM   #6
Thealien
Thealien's Avatar
I could’ve sworn the ones I have seen for sale with the oil field tubes were a bolt with a stud sticking out of the top? I believe it was done like this so that you do not have to loosen a manifold bolt if you need to remove the oil fill tube. I do not know for sure so I’m hoping someone with more knowledge than myself will chime in.
Old 03-16-2022, 12:20 PM   #7
cst204x4
I bought this one worked fine
1970 CST 4x4 collecting nos parts for this project
1972 cutlass owned since 1984
1972 cutlass conv
1970 Cutlass conv
1981 chevy shortbox
1986 grand national
2004 2500HD Crew Cab 66,000 miles
cst204x4 is offline   Reply With Quote
Old 03-16-2022, 06:52 PM   #8
Thealien
Thealien's Avatar
They actually had some listed for 1969 to 72 Chevy small block.
Mark
