Old 03-17-2022, 08:47 AM   #1
Thealien
Thealien's Avatar
Door switch grommets
I am trying to clean up all the wiring on the bronze blazer. I am missing the two grommets with the door switch wire goes through. They are pretty small. I have an assortment of grommets and none of them will fit. I have done a search on this forum in the Google search above and I’ve been unable to locate those little grommets.
Do any of you know a good source for the correct door switch grommets?
Mark
Old 03-17-2022, 09:32 AM   #2
CarlsLQ9SS
CarlsLQ9SS's Avatar
Re: Door switch grommets
I have been trying to find these as well with no luck. I am getting ready to have the cab sandblasted and debating on just leaving them in and covering them some how! I hope someone knows somewhere to get them.
Carl
1971 GMC short bed, (Henry)
Options I've added, tilt, ac, 8k tach,
Electric speedometer conversion for LS swap,
6.0 with 823 heads and BTR stage 4 truck cam,
4L80e, posi with 3.73 rear end,
Power steering and power brakes
Lowered 5/7. Frame up build.
CarlsLQ9SS is offline   Reply With Quote
Old 03-17-2022, 09:42 AM   #3
Accelo
Accelo's Avatar
These are actually plugs and I use them for electrical also. I just punch a hole in the middle for the wire(s). The smallest one is just under 5/16 at 7mm.
The size listed for each plug is the hole size.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Off topic:
I'm not a fan of sandblasting. Years ago my brother-in-law blasted his 62. The sand laid in all the crevasses and it ended up rusting out the body so bad he had to replace it. It was outside at the time. He still owns the car some 40 years later. That's the beauty of soda-blasting. It washes out with water.
Accelo is offline   Reply With Quote
