12-30-2003, 07:52 PM | #1 |
Watch out for your cornhole !
Skokie to the courtesy phone, pics here!
Here is the collapsable shaft. Where my finger is....
12-30-2003, 07:55 PM | #2 |
The shaft unbolts off of the column. The end of the column is splined where it goes on.
Depending on which tilt you use, the collapsing shaft might need to be shortened a bit. My stock non-tilt auto column has the shaft built onto it. There is no way to remove it and put it on another column. Just use a shaft off of a 3 speed column shift standard trans truck. They remove. Collapse as needed to fit.
12-30-2003, 08:32 PM | #3 |
computer illiterate
every auto non tilt column i have ever had (5 or 6) the shaft comes off just like all the others
72 2wd blazer 72 swb 4x4 |
12-30-2003, 09:33 PM | #4 |
Tx Firefighter
Thanks a bunch. Thats what I needed. |
12-30-2003, 10:31 PM | #5 |
Meathead.........
12-30-2003, 10:44 PM | #6 |
Tx
Can you show us whats to the right of that last pic you posted? Thanks |
12-30-2003, 10:52 PM | #7 |
12-30-2003, 11:06 PM | #8 |
Thanks again.
12-30-2003, 11:08 PM | #9 |
Open Sundays 10 till 10
your not using a big enuff torch
I'll get it unbolted
817-846-5476 parts for sale always 30 minutes south of Dallas on I35 WWW.BBSAutoSalvage.com bbs1969@direcway.com |
12-31-2003, 01:44 AM | #10 |
computer illiterate
it should come apart right where the big washer and the collar missing the bolt is that pic looks like a van tilt with the shaft already collapsed
i have a true truck tilt a van tilt and an auto non tilt column in the garage if you would like i will take a pic of all three tomorrow.
12-31-2003, 02:00 AM | #11 |
Meathead, I know you're right. I've had them that were 2 piece too.
But, not this one. It's a stock auto column out of a 68 truck. I went ahead and took the shaft all the way out. It's not sectioned like the other ones are. 1 piece all the way down to the collapse section. I layed it next to another shaft out of a normal 2 piece type column. See pic......
