Old 03-17-2022, 10:06 PM   #1
pringle85
pringle85's Avatar
WTB 70 6 lug axle shafts
My 70 GMC has the long (31-1/2") axle shafts with 6 lugs. The bearing surface on the axles are badly worn, and I'd like to replace them. I can find new axles, but they all seem to be 1/2" studs, while mine has the original 7/16" studs. Don't really want to have different size lug nuts front and back. Anybody on here do a 5 lug conversion and still have their good condition 6 lug axles?
pringle85 is offline   Reply With Quote
Old 03-17-2022, 10:13 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: WTB 70 6 lug axle shafts
I have a set.
Not sure how good the axles are.
I can send you some pictures.
Keith
Convert to disc brakes.
Old 03-17-2022, 10:22 PM   #3
lolife99
lolife99's Avatar
I checked mine on the bearing surface with calipers and the measured 1.616”
31-1/2” long axles.
I think shipping will kill the deal.
Keith
Old 03-18-2022, 10:33 AM   #4
pringle85
pringle85's Avatar
Thanks Keith. I will have to measure mine to what size they are at. I did measure them already, but only remember the difference between the worn and unworn bearing surface. You might be right on shipping, too. Zip is 49756 if you want to check cost.
Old 03-19-2022, 09:36 AM   #5
southern parts
southern parts's Avatar
you can use 4X4 axles out of 73-80 trucks too. same axle.
southern parts is offline   Reply With Quote
Old 03-19-2022, 10:47 AM   #6
pringle85
pringle85's Avatar
I thought those were a direct fit, but all of them I've found have 1/2" studs. Has anybody found or are aware of any 7/16-20 studs that could be swapped into these axles? Haven't had any luck finding any yet.
Old 03-19-2022, 02:20 PM   #7
pjmoreland
pjmoreland's Avatar
I am in the middle of rebuilding a 1970 12-bolt rear axle assembly. I saw your post earlier this morning, and it got me worried. I've been waiting for some Moser 14071750 axle shafts to arrive from Summit. I spent the last couple of hours looking online for a 7/16 stud with a .530 knurl, but like you I couldn't find any. As chance would have it, FedEx just delivered the axle shafts half an hour ago, so I measured the stud holes, and they are actually the correct size for 7/16 studs. There is a question on Summit about the stud size, and there is a "Product Expert" comment that says these axles are for 1/2 studs, but that is not correct. I installed a Dorman 610-186 7/16-20 stud and it pressed in perfectly.
pjmoreland is online now   Reply With Quote
Old 03-19-2022, 02:21 PM   #8
pjmoreland
pjmoreland's Avatar
More photos
Old 03-19-2022, 02:22 PM   #9
lolife99
lolife99's Avatar
I thought the 73-87 1/2-ton 4x4 axles used 7/16” studs also.
Am I wrong?
Keith
Old 03-19-2022, 02:43 PM   #10
pjmoreland
pjmoreland's Avatar
Am I wrong?
I believe you are correct.
Old 03-19-2022, 02:45 PM   #11
lolife99
lolife99's Avatar
The only 1/2” stud 71-87 axles are the 5x5 pattern axles.
Keith
Old 03-19-2022, 02:56 PM   #12
pjmoreland
pjmoreland's Avatar
For me, it was just a question of what size the studs were on reproduction axles.
Old 03-19-2022, 03:47 PM   #13
pringle85
pringle85's Avatar
Well fellows I guess I need to apologize for the runaround. I had tried to find the stud size of the replacement axles, and like pjmoreland the only reference I found was Summit's "expert" claiming they were 1/2" studs. I had a question into Moser asking about the stud size, but still haven't received a response. Guess I will go ahead and get new axles ordered up from Summit, and a special thanks to lolife99 for all of your help.
Old 03-19-2022, 04:18 PM   #14
67swb72klb
67swb72klb's Avatar
I have a set down here in Livingston county they been sitting for quite a few years..
Came out of my 67..
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 03-19-2022, 06:16 PM   #15
lolife99
lolife99's Avatar
Came out of my 67..
67 axles will be shorter than the “one year only” 1970 6-lug axles.
Keith
