Old 03-19-2022, 11:35 AM   #1
stepsider
stepsider's Avatar
gas pedal
Looking for a gas pedal that has a spring And pad that's on the end of the gas pedal unit, Not fasten to the floor. Don't want aftermarket. Maybe I'm thinking late model pickup ?
stepsider is offline   Reply With Quote
Old 03-19-2022, 11:49 AM   #2
geezer#99
geezer#99's Avatar
Re: gas pedal
I used one from an 80 gmc when I built my 56.
Old 03-19-2022, 12:10 PM   #3
Accelo
Accelo's Avatar
Re: gas pedal
Our C10's went to the pedal style you are looking for in 1972.
This began when they reverted from rods to a cable for the throttle. GM was having issues with the throttle binding at full throttle when the motor torqued over because of bad motor mounts. Back when they didn't have the interlocking metal to stop this when the rubber bond failed.
Maybe you are familiar with the bolt on adapter that goes between the newer style cable throttle and the old-style rod swivel attachment points? A member sells them and makes the conversion much easier. The modern bracket also has a mounting bracket for the THM 400 electric kick down switch. As GM moved the switch inboard, from the carburetor, when they changed to the cable. I believe the brackets to 1987 will work. That needs confirming.
Accelo is online now   Reply With Quote
Old 03-19-2022, 12:37 PM   #4
stepsider
stepsider's Avatar
Re: gas pedal
I have a 92 with a floor mount rubber. I wonder if the pedal part went missing and just left rod ? I might search for a late model pedal. Can't find then in the parts book.
Old 03-19-2022, 03:27 PM   #5
Classic Bowties
Always on the hunt...
Re: gas pedal
We have these GM NOS 1971-72 accelerator pedal pins and tension springs available in the below linked parts board f/s thread, we can also offer/combine ship the 71-72 style accelerator pedal and deluxe stainless pedal trim in either GM NOS or new repro. Let us know, Mel
https://67-72chevytrucks.com/vboard/...d.php?t=783148
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is online now   Reply With Quote
Old 03-29-2022, 12:25 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Re: gas pedal
I would just get one out of a '72 Chevy or GMC, like Accelo mentioned.....
LockDoc
Leon
