Rear drum missing spring
Hello,
I rebuild the rear brakes on my truck. I found nearly everything. But i didn’t find the strut spring for the emergency brake strut. Do i translate it wrong? Because I’m from germany or isn’t there nowhere some on stock? |
Who Changed This?
![]() Join Date: Jan 2013
Re: Rear drum missing spring
The strut spring isn't generally found in the spring kits, for some reason. You can purchase them separately, but I don't know about that in Germany.
I buy everything in the USA. But is this spring called strut spring?
Because i didn’t find them |
![]() Join Date: Nov 2017
It is called a strut bar spring. Napa in the US does sell them.
Search for anti-rattle strut spring.
Look here. https://www.thewrenchmonkey.ca/produ...arlson/h13382/ |
I’ve used a light duty spring like in this link to make my own.
Stretched out, flattened a bit and bent a couple pigtails on it. Worked great. Hardware stores have them. https://www.charleswareparts.org.uk/product/bpf117/ |
Thanks for the help. I found with the carlson partnumber a spring from raybestos. Now i got everything and i can place my order.
![]() Join Date: Mar 2015
My friend rebuilding his 1956 C10 just ran into the same thing. Purchased a spring kit and the strut spring wasn't included.
Maybe should call it a spring kit -1? |
At the body shop.
That spring broke on my dana 60 the brake adjuster keep on adjusting til it unthreaded itself.
Killed shoes and the drum. Ended up cutting the drum off with a torch.
" That didnt make it any newer " " Dont antique the equipment " |
Who Changed This?
I don't think that I have ever seen that spring in any kits, and I've installed hundreds of kits, over my lifetime.
At the body shop.
Available on ebay
I found it on Rockauto. Raybestos H1338. Thats the easiest way to order Parts from Germany.
But its not listet at the c10 parts. |
#13 |
I ran into this issue when doing the brakes on my 67 a couple years ago. After an exhaustive search I got an older guy at O'Reilly that really dug in and helped me out. He looked through some books and made a few phone calls. Ended up what I needed as actually on the shelf:
Brake Best part number H1338-2
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
