Old 12-30-2003, 08:04 PM   #1
BUXMAN66
go bucks!
different tach's???
i bought a tach dash off of e-bay (board member),and after doing some talking w/ the guy's at restoration world (full line of gm cars and trucks restoration parts)...and then his supplier.....american autowire......i now have been told that there might be a possibility that even w/ the correct style harness to hook up w/ my hei ignition...that gm had different styles of tach's and that some were only compatible w/ points/coil style of ignition. can anyone shed some light on the subject.....and also what the hell am i gonna do w/ a coil type tach...and i've got the hei style ignition?? any way of knowing/identifying this beforehand or is it just hook it up and hope??
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 12-30-2003, 08:08 PM   #2
1969 GMC
1969 GMC's Avatar
all 67-72 trucks had points style ignition. many people have converted their truck to HEI, and the tach works fine...sounds like the resto guys are blowing smoke up your a$$? you may have to wire the tach differently, but I dont know about this.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 12-30-2003, 08:14 PM   #3
jhow66
jhow66's Avatar
What color wires does your tach have?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-30-2003, 08:19 PM   #4
BUXMAN66
go bucks!
my thoughts exactly!! the guy at american autowire did give specific instances though....the early 60's years trucks, and others i dont remember exactly. he said the points style of tach read the pulse given off the coil...and that the circuitry was different......??
Old 12-30-2003, 08:21 PM   #5
BUXMAN66
go bucks!
i haven't recieved the tach yet ......from the big brown truck!!
Old 12-30-2003, 08:21 PM   #6
jhow66
jhow66's Avatar
What brand?
Old 12-30-2003, 08:30 PM   #7
BUXMAN66
go bucks!
it's a factory tach dash check it out: http://cgi.ebay.com/ebaymotors/ws/eb...tem=2449136434
Old 12-30-2003, 08:33 PM   #8
jmanz69
Careful, they attack...
jmanz69's Avatar
They all read the pulse off the coil. The HEI has a terminal that is labeled TACH. Just hook up the lead that would normally go to the (-) side of the coil and you are set. I think he may have been trying to get you buy something he has to sell. Whether it's a pionts or HEI, the tach is on the (-) side of the coil. It's the same reading, just a different location.
jmanz69 is offline   Reply With Quote
Old 12-30-2003, 08:35 PM   #9
s95930
A-Adam A-Adam
s95930's Avatar
I think they are confused. When I use my tune up tach on vehicles with points and vehicles with HEI. I don't do anything other than hook up the wires. I assume the tach in the dash works on the same principle.
70 3/4 ton GMC Camper Special
s95930 is offline   Reply With Quote
Old 12-30-2003, 08:42 PM   #10
jhow66
jhow66's Avatar
Nice looking dash. Just finished a setup just like yours for my brother-in-law. Coil terminal on tach goes to tach terminal on HEI. Other terminal on tach goes to a 12 volt switched source. These tachs work with both HEI or points as I have installed both ways .
Old 12-30-2003, 08:44 PM   #11
BUXMAN66
go bucks!
i don't see how he really has anything to gain by it but........i personally thought the only differences were a mechanical tach and a electrical tach.... there isn't any difference in the price for either harness.......whatever?!?
Old 12-30-2003, 08:46 PM   #12
BUXMAN66
go bucks!
thanks to all w/ the replies....i don't just plop down $400 bucks everyday y'know?!!!lol
Old 12-31-2003, 01:00 AM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
A mechanical tach would run off a cable like on the old 63 (I think it was 63) Corvettes and on many old deisel engines.
Old 12-31-2003, 04:58 AM   #14
Rooster's 67
Rooster's 67's Avatar
only issue you could have is there is actually a tach for 6cyl and 8cyl and they are different. the back of the tach will be stamped, mine reads 8CYL but very faintly.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 01-01-2004, 06:29 PM   #15
BUXMAN66
go bucks!
everything's been taken care of...in fact i've heard from the guy that i bought it from and he assured me that it is the same tach that he has in his own truck,...and running a hei.
Old 01-03-2004, 08:48 AM   #16
GMC Jim
GMC Jim's Avatar
If you want a tach that is just a little " different"..... Teleflex has a line of tachs used with marine engines.....Most are 6000/7000 RPM and are available in several styles, background plate colors etc....
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Old 01-04-2004, 03:30 AM   #17
1972C10
1972C10's Avatar
I had a really neat tach one time i got my 72 hooked it up the first day second day i upgraded to an hei it woudlnt work with the hei had to have the external coil ended up giving to a friend with a mid 80s ford. Some tachs wont work with hei mainly older ones.,
1972C10 is offline   Reply With Quote
Old 01-04-2004, 03:36 AM   #18
Hooter
My other Love
Hooter's Avatar
they tachs are all the same same reguardless of 6 cyl or 8, there is a set screw in the back of the tach to select either 6 or 8 cyl
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 01-04-2004, 05:53 AM   #19
1969 GMC
1969 GMC's Avatar
the only different tach is the diesel tach out of a medium duty truck, which is only labeled to 4k, as opposed to 5k on all gas trucks.
1969 GMC K2500
1996 Honda Accord
