Post Whore
![]() Join Date: Aug 2014
please help me remove this cigarette lighter before I...
I stripped my entire '71 cab but for the life of Jupiter I can not seem to get the silly chromey cigarette lighter out of the dash, what sorta hockey pockey is required to get this bad boy out
please help a brothah out Last edited by Gregski; 03-22-2022 at 10:25 AM. |
![]() Join Date: Jun 2005
Re: please help me remove this cigarette lighter before I...
There is a housing on the backside of the dash thats screws onto the lighter housing and holds it in. Just unscrew the rear housing and it’s out
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Yep what he said.
![]() 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
![]() Join Date: Jan 2012
Assuming you have a stock style lighter. Remove the lighter element, reach behind the dash and unscrew part #2 from part #1. You may have to put a finger or thumb into part #1 to prevent it from turning at first.
![]() Join Date: Dec 2013
it's electric , You should be all over it !
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
![]() Join Date: Jan 2001
And if you need to replace it, this one is a perfect fit:
https://www.amazon.com/dp/B09DZGJDZW...roduct_details
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Previous failed to mention that part 1 may be weld rusted to part 2 and that part 1 is impossible to get a good grip on. .
The Older Generation
I would spray the back of it with a little penetrating oil. It makes them unscrew a lot easier. LockDoc
If none of above works replace the dash
Who Changed This?
![]() Join Date: Jan 2013
Post Whore
thank you all I appreciate all of your input and advice, I just luv this forum, snide sarcastic comments always go to the top, LOL as they make me chuckle
#13 |
Post Whore
#14 |
In all seriousness, if you cant separate the #2 from #1, just a few seconds of a angle grinder with a thin cut-off wheel on the mid section will do the trick.
#15 |
Post Whore
so it's twist and pull back, otherwise it just spins
#16 |
Congrats on the extraction! Fyi, you got you a '67 only lighter element there. The ridged edge is the dead giveaway. '68-'72 were smooth like this so it would match the headlight, wiper and radio knobs.
