Old 03-28-2022, 09:03 AM   #1
Minkota
Power Steering Pressure Hose
I have a 67 with a SBC. The Power Steering hose started leaking on the metal tubing that connects to the steering box. The hose that is currently on it looks like the previous owner took a bunch of JIC fittings and a piece of Hydraulic hose and made it work. Does anyone have a part number of a hose that works?
I have read in a few posts that i need a hose for a 68, but there are a few different hoses available for the 68. Thanks
Hopefully the pictures are clear enough...
Minkota is offline   Reply With Quote
Old 03-28-2022, 01:19 PM   #2
HO455
Post Whore
HO455's Avatar
Re: Power Steering Pressure Hose
I do not believe there is an over the counter hose available that will fit without modifying either the hose or the fender well. I ended up rebending the hose where it goes into the box. (Not as simple as it sounds if you don't want any kinks.)
Of course, after I did that, I read that there is a board member who makes a pressure side hose. Do a search and you should be able to locate them.
The hose that you need would be listed as a 68 and up, as 67's came with a completely different style of power steering from the factory.
RIP Bob Parks.
Old 03-28-2022, 02:04 PM   #3
Minkota
Thanks for the response. I saw a few posts when I did my initial search and I think the member that was selling them was "Pickmup". I sent him a PM, but have not heard back yet. Thanks
Old 03-28-2022, 02:12 PM   #4
kwmech
That looks like a manufactured hose. Any hose shop should be able to replace the leaking piece
Old 03-29-2022, 08:53 AM   #5
Grumpy old man
Grumpy old man's Avatar
You have to determine what pump you have , The picture you posted shows the low pressure return line on the back of the pump you have now faces down , The lines sold by pickmup are different and being custom made of stainless they are expensive compared to standard lines , The best bet is to remove the leaking pressure line and try to match it up at the parts store , being that it's a 67 someone in the past probably converted it to power steering and used what parts they had , These pics should show what I'm trying to explain .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
