97 low pedal empty resivoir
As the title says: 97 K low pedal and the master is almost empty. There is no visible leakage. I'm thinking it's a leaking master.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
Re: 97 low pedal empty resivoir
could be leaking in the rear drums. I'd check there and the rear lines inside the driver's side frame rail to see if fluid pooled up in there.
Mike |
I’ll check there next. There wasn’t any brake fluid between the master and the booster yesterday when I separated them.
| Bookmarks |
