Old 03-29-2022, 12:19 AM   #1
cdub2010
Bowler clutch pedal conversion for nv4500/th400 swap
Any one use the Bowler 73-87 C10 clutch pedal kit. Im yanking the 454/400 out of my 1988 R3500 dually this spring in favor of a supercharged 6 litre/nv4500. This looks to simplify the job of sourcing a set of hydraulic hydroboost/clutch pedals for the swap, just add the new clutch pedal to the existing set add a wilwood master with linkage and your good to go. Id link to the site but not sure its ok, its easy to find if you google it.
cdub2010 is offline   Reply With Quote
Old 04-01-2022, 03:17 PM   #2
kipps
Re: Bowler clutch pedal conversion for nv4500/th400 swap
Just googling the kit, it looks like a duplication of the factory parts. The pedal looks identical to the factory pedal. The pedal bracket fastens to the brake pedal bracket in a similar way to the factory setup. The differences I see is the factory setup uses rivets to fasten the two brackets together, and the factory setup uses brace rods that go back to the firewall to stiffen everything.
Do a little searching for the factory pedal setup. You should be able to buy a used 1985-87 pedal assembly for a similar price to that kit. The extra bracing of the factory setup would be a bonus.
Use the factory 85-87 clutch master, and adapt it a -3an line using this fitting. https://ormebrothers.com/products/me...pter-dual-seat – choose the 3AN/12mmx1.0 option from the drop down menu.
For connections and instructions for the external nv4500 slave, look at this thread. https://67-72chevytrucks.com/vboard/...d.php?t=701900
Both the internal and external nv4500 slaves can be adapted to a -3AN fitting using the Russell 640281 fittings. The internal slave will need the gold-colored quick-connect removed before the 640281 fitting can be installed.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 04-04-2022, 10:40 PM   #3
v30crewcab
v30crewcab's Avatar
if you do the bowler route, make sure you make the braces that run from the pedal to the firewall were the master bolts up, otherwise it will eventually break the firewall out.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 04-05-2022, 08:29 PM   #4
44th Miss Inf
The factory braces for the 85-up pedals are pn 15521991 & 15522108. Though discontinued, i just bought a set a few months ago so there are still some on shelves
44th Miss Inf is offline   Reply With Quote
Old 05-20-2024, 09:34 PM   #5
cdub2010
Thanks for all the tips just following up - finally installed this, but it went in a 84 k30.
The setup from bowler is very nice, went together real easy, welded it all together and mounted up very nice and rock solid with the bracing. Cut my stock brake pedal. Used a Wilwood gs master, a quick connect fitting to 4an line to the release bearing and a gm remote reservoir. Ill probably redo my first attempt at bracing rod to the firewall. Similar money compared to a buying a used hydraulic pedal from ebay.
