Old 03-29-2022, 07:00 PM   #1
Thealien
Thealien's Avatar
3/4 ton brake booster support
I had purchased one of Pickmup's 3/4-ton booster and master cylinder kits a year ago. I was going to use it on my 2-wheel drive and went with Hydro boost instead.
It was sitting on a shelf and was paid for, so I want to install it on my 4 X 4 Blazer. Taking some measurements, it appears the wide bracket that goes from the firewall to one of the master cylinder mounting bolts on the front of the booster will not be long enough.
Does anyone have the support from a 3/4 ton they would like to sell?
Are the 1/2 ton and 3/4 ton brackets different? If not I still need a support and will weld it to length?
Mark
Old 03-31-2022, 10:10 AM   #2
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: 3/4 ton brake booster support
I might, I have some NOS stuff that purchased in a kit years ago. Ill look later tonight. Post some pictures.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 03-31-2022, 12:15 PM   #3
Thealien
Thealien's Avatar
I am pointing at the part
I am pointing at where it turns up and attaches to the front of the master cylinder mounting bolt.
It is about 10 1/2" long from the firewall for a 1/2 ton. I need a 3/4 ton that would be a couple inches longer or I will have to cut and weld?
I couldnt really tell but it is about 1 1/2" wide and turned up at the edges.
Old 04-01-2022, 07:45 AM   #4
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I've got a couple still on some boosters. I'll get one pulled off today if D.Passmore can't help ya.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-01-2022, 07:51 AM   #5
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I'm still looking, I can't get into my other barn till this weekend. So go ahead.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 04-02-2022, 10:26 AM   #6
JQ-72
JQ-72's Avatar
The 3/4 ton lower support is longer than the 1/2 ton to compensate for the thicker booster. I have one I'd sell if no one else can help you.
Joshua
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track
72 Cheyenne Super swb. 350/350 A/C, bucket seats
72 Cheyenne swb. Factory 402/400, tilt, posi, A/C
72 Cheyenne Super K-10. 350/4 spd., posi.
72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack
72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior
JQ-72 is offline   Reply With Quote
Old 04-03-2022, 05:54 PM   #7
jimmy70
jimmy70's Avatar
Mark, sent you pix / pm'd you my paypal account. I do have your mailing address. Let me know when you have paid. thx again, marko
jimmy70 is offline   Reply With Quote
Old 04-03-2022, 06:15 PM   #8
Thealien
Thealien's Avatar
First I want to thank everyone that took the time to post pictures and reply to my want to buy request.
Jimmy70 Seems to have been able to fulfill my request.
