Chance
![]() Join Date: Sep 2001
Speedo Reset???
How does one reset the speedometer to all zeros?
its all about the +6 inches
Lots of driving.
Not sure if this will work on these trucks, but in the past I have put a drill on the end of the speedo cable and let that pull the odometer around. I would have a little concern about bottoming the speedo out as far as MPH's go and doing damage, but if you take it easy and get a feel for it it may be able to be done.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I did the drill trick worked pretty good only racked up about 30,000 mile's on my drill..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
