![]() Join Date: Jun 2011
heater motor hose
Is there a source for the small hose on the heater fan motor yet?
Tom in Iowa 68 L88 C10 68 4x4 C10 soon |
Re: heater motor hose
The Corvette guys have everything.
It may fit? https://www.ecklers.com/ac-blower-mo...0-44239-1.html |
Blower motor cooling tube I used came off a late model dodge of some sort I had laying around, I used to work at the dealers so it was just a fresh rubber piece I had saved during work. It fit just fine although not an exact match. I would imagine many GM models would have the same match, I know some are long, others short so use pictures to get close to your size or length of tube. Should be easily found.
http://67-72chevytrucks.com/vboard/s...d.php?t=806864 Thread with pictures of hose if you need. Search the web for the part and try a GM hose that looks close. Bob |
| Bookmarks |
