VIN Lookup Issues
HI!
I am trying to decode my VIN on my GMC C15. When I look at the GVW Plate on the door pillar, the VIN shows as C9S1491103551. Now, when trying to use the VIN Decoder either on this website or in LMC's Magazine I have, the 2nd digit should be a Letter to denote the engine designation. This one shows a 9? What am I missing? When I look at the sticker in the glove box, the model number shows it to be a 2WD, V8, 1/2 ton, 127 WB, '70-'72 Fleetside. All of which sounds right from when I bought it. ![]() Last edited by Atmosphere31; 04-02-2022 at 02:52 PM. |
![]() Join Date: Dec 2009
Re: VIN Lookup Issues
Here is a couple of resources.
Link: https://67-72chevytrucks.com/vboard/...light=bruceman Link: http://outintheshop.com/ Hope this helps.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#3 | |
Even if we disregard the 9, the S would denote the truck being an inline 6, but it has a 350 in it (which matches the SPID label). I am not sure this is the correct VIN plate for this pickup. Is there anywhere else the VIN would be stamped on the frame or something? |
There is partial vin on the drivers side (top of the frame).
Link: https://67-72chevytrucks.com/vboard/...t=vin+on+frame
Post a pic of the spid (sticker) in the glove box.
That might reveal something. Glove box doors are often changed out. |
The ‘9’ denotes a Canadian built truck.
Look here. https://www.67-72chevytrucks.com/vbo...d.php?t=573513 |
#7 | |
This is the SPID on the Glove box door. All of the info lines up here. Truck has a 350, Fleetside, Rear Leafs ect. So I have no reason to believe it is incorrect. Unfortunately this one didn't come with a covered top Sticker so the VIN is not readable. Which makes me even more wary. When Looking at the VIN, it decodes as 2wd (correct) Inline 6 (V-8 350) 1/2 Ton(correct) 70-71 Stepside (Fleetside) Oshawa Built (correct) 1971 (Not sure) Correct values are in brackets. |
Interesting, don't know much about GM Canada myself, but nice to learn something new.
To A...31 (OP), sounds like a cool truck. Guess it may be a 69 built in Oshawa with an engine swap. Aftermarket parts books are not the best source for reference. http://67-72chevytrucks.com is a wonderful place for information, as you can see. Welcome ![]() Bob |
Roadtrip!
![]() Join Date: Feb 2003
The glovebox door is not for a 67 gmc. Do you have a title? Does the truck have a small back window or side marker lights?
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Roadtrip!
5 lug wheels? I think 71 had the clear over the spid. Something doesn't look right on the spid. The upper part is older than the lower part...
#13 |
SPID label appears to have clear protectant over the bottom portion. That may be the reason the top portion looks older.
I wonder if Canadian vehicles had the SPID description portion added to the top half? Last edited by HotWheelsFan; 04-02-2022 at 12:24 PM. Reason: Second thought added. |
#14 |
Isn't the NA9 for an evaporative emission system? (charcoal cannister). I didn't think they were available in 1967
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
#15 |
#16 |
Another tell-tale would be power steering.
The spid says it has it. The 67 had power assisted ram, 68 on up had ps gear box. Could have been changed. Lots happen in 50 years. |
