Old 12-31-2003, 01:34 AM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Door jamb vent
What year did the pressure release thingy in the driver's side door jamb first appear?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-31-2003, 08:03 AM   #2
Tim Christian
Tim Christian's Avatar
Smile
I think it was a 72 thing only. Someone please correct me if I am wrong.
Tim Christian is offline   Reply With Quote
Old 12-31-2003, 09:31 AM   #3
JimKshortstep4x4
Talking
71's have them, also.
Jim
Old 12-31-2003, 11:40 AM   #4
FRENCHBLUE72
PROJECT 7DEUCE
I am guessin that 69 's did not have em??? I have been looking at a 69 part's truck that has the jamb vent and a little square vin tag in the jamb,think this truck has been messed with ???
MEMBER #6377
Project "7DEUCE"
Old 12-31-2003, 11:48 AM   #5
J.Lance
Too many is never enough!
vents
From what I've seen they appeared in '71 but not all '71s have them. I had a '71 GMC that does and a '71 Chevy that didn't, I don't believe make has anything to do with it though. I remember thinking that all '71s had them and maybe the cab wasn't original but I asked the local experts and that was the info. I was told.
As far as that '69 parts truck, does it have a throttle cable or rod? Not that these can't be change but if it is a cable, possible that the cab is not '69. If it was coverted to a cable, the holes should still be on the firewall where the bracket bolted that held the pivot arm for the rod (I think).
Jason
1968 K10 SWB Fleetside
1971 K2500 GMC LWB
1968 K20 (later frame, donor body)
1972 C20 LWB parts truck
1993 K2500 Suburban, tow rig, 454, 4L80E
NEW!! 18' Siem's car hauler
2004 Honda Odyssey (family man!)
J.Lance is offline   Reply With Quote
Old 12-31-2003, 12:26 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
I can not rember seeing a linkage rod just the cable (square)hole.... It has outta state plate's on it, has a title, and it's hard to read the frame # to see if they match the vin#(too much oil,greese and crap... I did have a friend who is a sherrif call in the plate's and the truck is not stolen??? Should I buy if for 100$$
MEMBER #6377
Project "7DEUCE"
Old 12-31-2003, 12:31 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
The door jamb has a little square vin tag like truck in picture with the vent right below it and it appear's to be stamped in nut cut...
If I put up the vin # can someone tell me a date it was made ... Like early or late 69???
MEMBER #6377
Project "7DEUCE"
