12-31-2003, 01:50 AM | #1 |
PROJECT 7DEUCE
Grill fix idea's
Anybody got any idea's on how to fix this outside of getting a new grill ? Also I would like to keep the grill aluminum color and not paint it.. Any idea's would be great.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-31-2003, 03:24 AM | #2 |
You can repair the aluminum and then buff it out.
I picked up some repair rods at a truck show once it worked real well, even polishes. It's called Aluminum repair rod and its from Pro Products inc. 1-800-822-6935 Hope that helps
PR Too many projects, not enough time! 72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold! 69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam. 78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's 77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs |
12-31-2003, 12:17 PM | #3 |
67-72 Addict!
Those aluminum rods are pretty slick and only require a small propane torch.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
