04-04-2022, 11:10 PM | #1 |
Differences fleet side box 60/62 vs 63/66?
Have what I believe to be a factory 61 4 x 4 that looks to have a fleet side box that does not fit/bolt to the frame in the factory location as it should. Wondering if I have a later 63/66 fleet side box here. Is there a difference between early and late 60/66?
Steve weim55 Colorado Posted via Mobile Device Last edited by weim55; 04-05-2022 at 10:57 PM. |
04-05-2022, 12:12 AM | #2 | |
But Found Her 25yrs Later!
Re: Differences fleet side box 60/62 vs 63/66?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
04-05-2022, 12:14 AM | #3 |
Exactly my experience. Any idea of the rest of the holes in the frame versus box ahead of the axle?
Steve weim55 Colorado |
04-05-2022, 12:19 AM | #4 |
I'm not sure what you are asking.
04-05-2022, 12:24 AM | #5 |
I noticed the box is not bolted to the frame at all at the rear portion because the holes-mounts from the box do not match the frame as you described. Just curious if the frame width is the same 60-66 AHEAD of the axle - if wider 60-62 frame is JUST The rear portion of the frame? Thanks,
04-05-2022, 12:36 AM | #6 |
I believe the rails are parallel from the back of the cab to the back of the bed. The frame rails taper noticeably under the cab.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
04-05-2022, 02:53 AM | #7 |
This is my '62 frame, maybe you can tell the difference, I have no comparison
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
04-05-2022, 12:22 PM | #8 | |
(under the tailgate) has a wider mounting point for 60-62. If your current sill is too narrow,you either need to modify it to fit or purchase one for a 60-62. |
04-05-2022, 02:18 PM | #9 |
The rear cab mounts line up fine for all 60-66. The frame gets wider somewhere under the bed for the 60-62.
However, several on these forums have made newer or older beds and cabs work on either frame.
04-05-2022, 09:20 PM | #10 |
No.
The frame tapers from the engine bay through to under the cab on the 60-62, and is parallel from the cab wall back. The frame tapers in the engine bay to the firewall on the 63-66, and is parallel from the firewall back. Because the frame continues tapering under the cab on the 60-62, the rear parallel frame rails are further apart.
04-05-2022, 10:55 PM | #11 | |
Steve weim55 Colorado Posted via Mobile Device |
04-05-2022, 10:57 PM | #12 |
Thanks everyone for the replies. I will have a closer look at the truck this weekend and compare notes
04-05-2022, 11:57 PM | #13 |
Take a look at Harald's frame and notice the two holes on the cross sills above where they mount to the frame. Then take a look at the two holes on the cross sills above where they mount to the frame on my 63 frame circled in blue. Notice how on the 60-62 frames, the cross sills mount to the frame using the outer holes on the mount pad and the 63-66 frames use the inner holes on the mount pad. I'm thinking the only crossmember you will have an issue with is the rearmost one with the different mounting style.
Of course, if someone who has a bed apart currently could confirm this with measurements, that would help a bunch. Although not the greatest picture, the second one shows a 63-66 frame stacked on a 60-62 frame. You can see the difference in width at the rear isn't a large amount
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
04-06-2022, 01:45 PM | #14 | |
I could have sworn my 65 cab rear mounts bolted right up to my 62 frame. But it's been a long time. Thanks for the correction.
04-06-2022, 02:27 PM | #15 | |
The location of the bolt holes is the same, but the physical mounts on the frame will be different. The front cab mounts don't line up, but I think replacement front cab mounts have holes in both places.
04-06-2022, 04:42 PM | #16 |
That explains it. Thanks
