Old 04-06-2022, 11:09 PM   #1
Arnulfo
Factory propane C30
Picked up this little gem. Glove box rpo for propane. Was a gubment truck in san diego back in the day.46k actual miles and runs like it. Minor rust issues otherwise a solid one tonner.propane about 3.50 a gallon right now. Beats the hell out of $6/gal for gasoline. My new daily driver. Drove it home to L A From SanDiego and she never skipped a beat!
Arnulfo is offline   Reply With Quote
Old 04-06-2022, 11:48 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Factory propane C30
That's neat! I have zero experience with propane powered vehicles, but is there a special place you have to go for a fill up or can you roll up to any place that sells propane in bulk for refilling grills and such?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 04-07-2022, 12:30 AM   #3
truckster
truckster's Avatar
I didn't know there was an RPO for propane power. Could you post a pic of the SPID? I'd be curious to see it.
One of the advantages of propane is that it burns really clean. The inside of the engine should be really clean.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 04-07-2022, 01:00 AM   #4
bigdog55
bigdog55's Avatar
Any place that sells in bulk will fill it. It's the same as the stuff for your house. I have ran on it for years. And have driven cross country on propane.
Brian
bigdog55 is offline   Reply With Quote
Old 04-07-2022, 08:06 AM   #5
palallin
Do we see break fluid leakage on the pass. side front wheel?
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 04-07-2022, 09:08 AM   #6
BigBird05
You should be able to drive a propane truck 1,000,000 miles!
BigBird05 is offline   Reply With Quote
Old 04-07-2022, 11:01 AM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
L56: Liquid Propane Gas Engine Conversion
From here- http://outintheshop.com/options.html
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 04-07-2022, 03:23 PM   #8
truckster
truckster's Avatar
Is it an Impco unit? I've service many of those back in the day.
Old 04-07-2022, 04:38 PM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
When I worked as a mechanic, we acquired a customer that had a fleet of over 100 Datsun (yes, it was that long ago- it wasn't Nissan, yet) pickups that were converted to propane. Servicing the system was a thing that I did. Another was installing a steady supply of ignition modules. The plugs ran clean, so they didn't bother to tune them up. Huge plug gaps and the ensuing high current through the modules was a common problem with those trucks. They'd generally fail at around 95k miles. We kept one in stock at all times to save them money on downtime. You still have to go through the trouble shooting steps, though. The other two techs would just throw a module on a truck when it came in. One didn't revive, and they called me in from book work (I was in uni at the time). It was the pick-up on that one.
~Steven
Simi Valley, CA
Old 04-07-2022, 06:41 PM   #10
Arnulfo
The brakes were completely redone,i.e. new shoes,wheel cylinders, drums resurfaced. Stopped the way drum brakes should. The propane system is an IMPCO Model E.
Old 04-08-2022, 12:41 AM   #11
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
That's a really Cool find, Hank Hill would love that truck! I'm sure since it's factory propane it was gas tank delete, what's in the spot where the filler neck would be?
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 04-08-2022, 01:59 AM   #12
Bob B.
The L56 option actually did not include the propane equipment like the tank, regulator, or mixer. What it did include was special valves and hardened valve seats to run on gaseous fuels along with a few other engine modifications. Trucks were built with gasoline fuel systems and after delivery the truck was sent to a company like Impco who removed the gasoline system and installed the propane equipment and tank. I think the L56 option was only available with the 250, 292, and 327 or 350 depending on year. In later years the option became KL5 gaseous fuel prep., same thing for propane or natural gas.
BTW, about the filler neck hole in the cab: There was a rubber plug that fit into that hole. Not only did propane fueled trucks use that plug, but also C50's and C60's that had saddle fuel tanks instead of the in-cab tank. Ought to be a part number for it!
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 04-08-2022, 05:22 AM   #13
Arnulfo
It does have a gas tank. looked and smelled like it was coated with diesel or some other product to prevent corrosion.
Old 04-08-2022, 08:21 AM   #14
Steeveedee
Who Changed This?
Steeveedee's Avatar
Hmmm...I wonder where all those brand new Q-Jet carburetors went.
~Steven
Simi Valley, CA
