Old 04-07-2022, 09:36 AM   #1
Detroit steel
i removed windshield ,can i re-use the weatherstrip or should i replace it ?
the windshield was busted , i removed it without damaging the seal but before i replace the glass with the used seal im curious whether i should replace it anyways . dont like to do things twice and definitely dont want to have to pull the new windshield and run the risk of damaging it in the process . 1972 C-10
Detroit steel is offline   Reply With Quote
Old 04-07-2022, 11:42 AM   #2
57larry
Re: i removed windshield ,can i re-use the weatherstrip or should i replace it ?
I would put a new one in
57larry is offline   Reply With Quote
Old 04-07-2022, 12:08 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Definitely a new one. If your old seal was original, it's 50-year-old rubber.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 04-07-2022, 12:27 PM   #4
Old 04-07-2022, 01:18 PM   #5
68 C10 Driver
I concur, get a new seal. The old one will likely be very stiff if not hard to the point it will crack.
68 C10 Driver is offline   Reply With Quote
Old 04-07-2022, 01:42 PM   #6
notsolo
notsolo's Avatar
I reused all glass weatherstrip on my Blazer, Lock doc I think had a post about mixing wintergreen oil and xylene.....applied after the gaskets are cleaned with soap and water. This makes them soft and ply able again....I did mine 10 yrs ago still in good condition not dried out.
notsolo is offline   Reply With Quote
Old 04-07-2022, 02:03 PM   #7
bry593
Aftermarket windshield weatherstrip does not fit correctly. Ask anyone who has actually installed a windshield their opinion. Those are the guys to listen to. I'd say if your original is still pliable, then reuse it.
Curious about this wintergreen oil. What the heck is that?
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs
bry593 is offline   Reply With Quote
Old 04-07-2022, 02:24 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
My seal was original to the truck. When I cleaned up the roof and painted it prior to the installation of the cabover camper shell, I cut the old one out, as it was hard as a rock. I bought a new one from LMC; it works fine.
~Steven
Simi Valley, CA
Old 04-07-2022, 02:27 PM   #9
Orange71shorty
My original was in great shape so I washed it thoroughly with hot soap and water and re hydrated it with Vaseline. Look perfect ten years later
Orange71shorty is offline   Reply With Quote
Old 04-07-2022, 03:13 PM   #10
notsolo
notsolo's Avatar
Leon aka Loc Doc, his original post goes back to 2006, also a problem then replacement rubber not fitting, I bought Wintergreen oil 4 oz bottle and mixed 50/50 with xylene as recommended. ...you will need some heavy duty gloves, it eats right thru nitrile gloves.
Old 04-07-2022, 04:12 PM   #11
Detroit steel
i believe the one i pulled out was aftermarket and still very soft , the guy who owned it before i got it must have replaced it but im not gonna take a chance . order a new one tonight . thanks for the reply .
Old 04-07-2022, 04:52 PM   #12
mr.mud1
mr.mud1's Avatar
just my 2 cents worth but i had a new windshield put in my 72 truck last fall,and took a new rubber in case they needed it.they used it and did a horrible job,it didn't fit well,the stainless trim didn't fit in the seal.i complained and went back with the original rubber all cleaned up and they did it again,a much better job with the original seal.having said that,how much was the guys doing it and how much was the repro seal?i guess i'd use a new one,if you had no choice but mine lived to fight another day so i was happy with that.
mr.mud1 is offline   Reply With Quote
Old 04-07-2022, 05:01 PM   #13
Detroit steel
the one that was in there was in real nice shape and i was careful not to damage it when i pulled the glass but i did notice some streaks where water was getting behind the seal , not sure if there is a easy solution to stop that ? thanks for replying , your 2cents is appreciated .
Old 04-07-2022, 10:31 PM   #14
Peanut74
Here is a thread where I asked the same question and also about the install:
http://67-72chevytrucks.com/vboard/index.php
In short the consensus was if the old gasket was good reuse it. This was especially true if you where installing the chrome trim. As for a new gasket the one of choice is the one from Precision. That is what I used for my new windshield install that also used the trim ring.
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 04-08-2022, 08:59 AM   #15
1967-C10
1967-C10's Avatar
suggestions for replacement Window rubber ?
Brand ?
1967-C10 is offline   Reply With Quote
Old 04-08-2022, 09:18 AM   #16
68 C10 Driver
Wow, that is a neat trick, thanks for that insight! Too bad I already removed mine and bought new. Tossed the old ones out sometime in 2020.
Old 04-08-2022, 08:17 PM   #17
Peanut74
Precision Rubber seems to be the brand the professional installers like the best.
Old 04-09-2022, 12:13 PM   #18
Accelo
Accelo's Avatar
Just had my front window installed. The Precision gasket worked nicely. Chrome sits flat. Installers liked the gasket. I would ask the installer what they prefer.
Accelo is offline   Reply With Quote
Old 04-09-2022, 04:37 PM   #19
Detroit steel
that looks good , i think im gonna order the precision seal
