Old 04-08-2022, 12:56 PM   #1
BrentBTK
TH350 shift firmness
I've got about 70 miles on my new motor install. SBC 385/409 HP/Tq mated to a TH350. Final gear ratio with my tires is about 3.21 I also replaced the torque converter with a 17-2100 RPM stall based on Blueprints recommendation. What I have noticed, is it seemed to shift much firmer before the swap. The shifts now are very soft. Is that related to the converter change? Anything simple I can do to firm things up a bit?
BrentBTK is offline   Reply With Quote
Old 04-08-2022, 01:10 PM   #2
tdangle
tdangle's Avatar
Re: TH350 shift firmness
I would think it may be the torque converter. At what RPM are you comparing shifts at? if just cruising you probably would have softer shifts, at full throttle I would not think there would be much difference. make sure you have the kick down rod adjusted correctly
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 04-08-2022, 01:23 PM   #3
leftybass209
leftybass209's Avatar
I wouldn't ever describe a TH350 as having a firm shift, even from the factory, unless it's had a shift kit installed, or during kickdown operation. At light and part throttle, I always described them as soft to slightly crisp.
Terms are vague though, so it helps to describe exactly what's happening with the shift sometimes over text.
Now, my 700r4, that's a firm shift, with slightly a lunge from 1st to 2nd. Completely different feel than the TH350, and i WOULD absolutely describe it as firm, lol
leftybass209 is offline   Reply With Quote
Old 04-08-2022, 01:24 PM   #4
BrentBTK
I still have to get the kickdown properly adjusted. Shifting across the board is just softer. Even if I run it up to around 3500RPM and shift manually, they are very gentle. Easy acceleration, hard, no real difference in firmness. I haven't gotten into it too hard as the motor is brand new.
Old 04-08-2022, 01:26 PM   #5
BrentBTK
Originally Posted by leftybass209 View Post
I haven't ever known a TH350 to shift firm unless it's had a shift kit installed, or during kickdown operation. At light and part throttle, they are soft to slightly crisp.
I certainly wouldn't have called the shifts "hard" before, but they are significantly softer now.
Old 04-08-2022, 03:04 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
You won't fry a 350 as quickly as a 200 or 700 if the detent cable isn't right, but you're not doing it any favors, either.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 04-08-2022, 03:12 PM   #7
BrentBTK
Could you elaborate? I'm not a trans guy. I assume you mean the kickdown cable? Isn't the purpose of it to downshift the trans under full throttle when vacuum isn't available? How does that not being adjusted affect reliability or firmness of the shifts? If I manually shift into 2nd under acceleration, aren't I doing the same thing? I appreciate the advice, I just don't know what I don't know.
Old 04-08-2022, 03:26 PM   #8
pontiacvince
pontiacvince's Avatar
Check to see if your vacuum modulator is the adjustable type. Most are. Pull the vacuum line off and you should see a small screw that you turn in to adjust the firmness. Make small adjustments till you get it where you want it.
pontiacvince is offline   Reply With Quote
Old 04-08-2022, 04:48 PM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
It isn't just for kickdown. The cable also adjusts system pressure. With the cable fully retracted it will shift lazy/slip a lot, if the cable was pulled fully out it will shift more firmly. People call it a kickdown cable because of its most obvious function. My take with the converter is that shifts will be soft at part throttle, but once the rpms are high enough, coupling is good enough for firmer seeming shifts.
~Steven
Simi Valley, CA
Old 04-08-2022, 04:58 PM   #10
BrentBTK
Awesome explanation, thank you! I'm going to have to do some research on setting it up.
Old 04-09-2022, 08:10 AM   #11
Bigdav160
Bigdav160's Avatar
On a 700R4/200-4R? Yes the TV controls the pressure.
It is strictly a detent (downshift) control on the TH350. The vacuum modulator controls the pressure on a TH350.
I suspect the new engine has different vacuum characteristics therefore it shifts different. Adjust the modulator or install a shift kit (superior HP is my TH350 favorite)
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 04-09-2022, 08:57 AM   #12
BrentBTK
That's what I have been reading as well. I'm gonna try to adjust the modulator. I at least feel confident I'm not hurting anything not having the cable connected until the proper bracket arrives.
Old 04-09-2022, 09:34 AM   #13
Steeveedee
Who Changed This?
Steeveedee's Avatar
I stand corrected.
~Steven
Simi Valley, CA
Old 04-09-2022, 09:38 AM   #14
Accelo
Accelo's Avatar
Any time one goes up, with the torque converter stall, you will go down in perceived shift firmness. Higher stalls have more slip.
High stall converters will not immediately drag the engine rpm down like a low stall. More slip is designed into the system. You will get used to it.
You may help the situation by firming up the shift. It will make difference but not a significant difference.
The motor indeed has different vacuum characteristics. In all likelihood it is less vacuum and that would equate to harder shifts not softer.
Only change, to the transmission, was the converter. Shift timing is unchanged. Logic dictates it's converter related.
Cheers
Accelo is offline   Reply With Quote
