Old 12-31-2003, 02:55 AM   #1
dinnut
dinnut's Avatar
whats the difference in bendix and delco brake boosters?
im wondering because soon i hope to convert to discs and autozone and oreilly ask me if i have bendix or delco-moraine type brake systems when i ask for a booster and master cylinder.
what is the difference?
which should i buy for my 70 when i put front discs?
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-31-2003, 03:37 AM   #2
Hooter
My other Love
Hooter's Avatar
depends if you like a square master cylinder or a round one
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 12-31-2003, 04:07 AM   #3
Southpa
Southpa's Avatar
I prefer Bendix over Delco. The master cyl. is much beefier and has two crosswise holddown clips for the cap. The pic shows my two earlier systems, both single clip Delco M/c's, which leaked constantly. Drum/drum m/c (equal size fluid reservoirs) and disc/drum m/c (fwd res. larger) I also opted for the deeper 3/4 ton booster for my 1/2 ton truck. Works great. I don't know if Delco and Bendix boosters are that much different from each other tho. Hope this helps a bit.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 01-01-2004, 06:07 PM   #4
dmec
dmec's Avatar
the difference is in the depth of the hole in the apply piston on the master cylinder. dont remember which style uses deep hole but you must use booster with longer rod that fits into the rear of master cylinder. vice versa for other set up. shallow hole on master, short rod on booster.
dmec is offline   Reply With Quote
Old 01-01-2004, 06:09 PM   #5
dinnut
dinnut's Avatar
oh. so i have to buy a matching booster/master setup? thanks
70 longbed
496/th400/Ford 9"
Old 01-01-2004, 10:51 PM   #6
Sweet72
Sweet72's Avatar
This really is only a little restoration trivia, but the Delco Morraine booster had a cadmium plated finish and the Bendix was painted black.
-Sam
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 01-01-2004, 10:59 PM   #7
dinnut
dinnut's Avatar
thats a nice thing to know sweet72... im not really going for the "restored" look as much as im looking for the restified look.
that may add to the decision imake
70 longbed
496/th400/Ford 9"
Old 01-01-2004, 11:15 PM   #8
Sweet72
Sweet72's Avatar
The research involved in putting one of these "relatively new" 67-72 trucks back to orig is something that keeps me interested in this truck project/obsession. Even though I plan to deviate and add some not-so-stock go fast goodies etc., I still want to know what it looked like off the assembly line.
