![]() Join Date: Apr 2006
Brake Hose Debaucle
OK, Need some guidance. I'll try and be brief.
My truck is a 68 Short Stepside - power nothing from factory. Years ago, installed CPP disc brake conversion kit and ran with basic original non-power master cylinder. At that time, also installed new stainless steel brake lines. All good. Fast forward, I'm working on rest of my build and installing new power brake booster, had an issue with one of the CPP calipers during bleeding and had to replace. 1) Ended up buying 2 new calipers for 72 Chevy truck. The hoses I had from CPP kit would not work as they had a smaller diameter at the banjo fitting. 2) Bought 2 new 72 Chevy truck brake hoses. Banjo diameter problem solved and drivers side hose worked fine, but the passenger side hose has a larger diameter fitting that connects to the hard brake line so the passenger side won't fit. Verified that the DL and PSGR side brake lines have a different fitting. Anyone experienced this? Do i need a fitting that converts the small hard line to the larger flex line fitting? New/Different stainless cross line? Right now I hooked it up with 2 drivers side hoses, but I don't feel comfortable with it being "rigged" like that when it's the braking system, plus it doesn't bend correctly. Any help is much appreciated! I've done these brakes like 3 times over! I want to get it done right, once and for all. Thanks! |
![]() Join Date: Mar 2015
Re: Brake Hose Debaucle
This is a new one on me. I was under the impression the differences was in the angle of the fittings not the hole diameter. Is it possible you received an incorrect caliper?
Another issue is the 72 hoses connect in front of the cross-member and the 68 has the connection on the rear of the cross-member. I have the factory hoses that were included with the CPP kit. I didn't use them as they had interference issues everywhere. Getting something I was satisfied with on the front brake hoses was a hassle. I ended up converting my flexible hose connection point to the front like stock. You should be able to get yours to work with the rear connection points as others have. Pictures would help. Pictured below is the stock hoses for a 72. Opps, I didn't read your posting close enough. You are conserned about the other end, not the caliper side. I know it's the same size lines, on both sides, on my truck Last edited by Accelo; 04-12-2022 at 01:25 AM. Reason: added info |
I stumbled on a thread where someone just used an adapter to reduce/enlarge the orifice. It'd just be a matter of matching up the right diameter and thread size.
When I order brake hoses or power steering hoses online I use Napa Auto online for reference since they will put a picture of each hose end along with the size and thread pitch, od, or id. That way if I don't know the exact year of what I need, I can quickly view a few different years and figure it out.
If they are reasonable in price I will purchase them there.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW |
I should be out by my truck before I open my mouth but I went through a struggle with brake hoses for my 72 Cheyenne Super 20 truck.i bought several pairs of hoses and all were too short.1/2 ton hoses I think?anyway i finally got hoses from a man in Michigan.i do remember both ends were,as the pictures provided by Accelo show,at the ends that hook up to the hard lines,both different and each hose had a different sized inverted nut as I recall
