04-11-2022, 04:12 PM | #1 |
Almost Satisfied
Gas Pedal Help
My donor was an 05 Yukon Denali. It came with the pedal like this on in the picture. I modified my firewall to allow this to just bolt in and thought it would be perfect as the gas pedal sits just lower than the brake pedal. After driving the truck for some time now I really want the gas pedal to be closer to the firewall. Any ideas on how I can achieve that? Are other pedals interchangeable with my harness on the pedal?
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
04-11-2022, 06:51 PM | #2 |
Re: Gas Pedal Help
looks like you have an adjustable height pedal. I'm wondering if theres a way to move it closer my activating the motor on the pedal.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
04-11-2022, 08:59 PM | #3 |
Re: Gas Pedal Help
I was thinking the same thing as V30. When that pedal was in the Denali it was adjustable. A cable like a speedo cable runs to that black plastic assembly, turns it and makes it longer or shorter. With the cable gone you could manually turn it to adjust the pedal where you want it. You could also remove that adjustable assembly and just replace it with a rod or something at one fixed position that suits you.
04-11-2022, 09:06 PM | #4 |
Re: Gas Pedal Help
Here's a picture of a pedal like yours. The black adjustable part is a little worm gear assembly. Manually adjust it to get the height you want.
04-12-2022, 09:25 AM | #5 |
Almost Satisfied
Re: Gas Pedal Help
Well, I feel pretty dumb but excited to see if that will work. Thanks guys. I'll keep you posted.
04-12-2022, 01:52 PM | #6 |
Re: Gas Pedal Help
There is the Vette pedal. Obviously would need to check compatibility. A user here makes a mounting bracket. https://67-72chevytrucks.com/vboard/...d.php?t=631165 Have one in my truck.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
04-18-2022, 02:54 PM | #7 |
Re: Gas Pedal Help
71Step, just came across this thread. I have a pedal from a 2005 GMC Yukon that was the same as yours. What I did was remove the plastic part for changing the pedal postion. Cut off the upper part of metal at top, and also upper part of the pedal arm. Used the hole where the plastic piece was, drilled hole in pedal arm and bolted together. After installing and adjusting pedal where it felt good I made a stop so that it moved the main parts. (This could be welded but I didn't.) This isn't a very good explanation, but hopefully the pics will help. Any questions let me know...Jim
Pic 1 was when I first installed in truck. Next three pics are close ups I took today.
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
04-25-2022, 09:49 AM | #8 | |
Almost Satisfied
Re: Gas Pedal Help
04-25-2022, 07:42 PM | #9 |
Re: Gas Pedal Help
Be glad to help anyway I can...Jim
