Old 04-13-2022, 12:24 AM   #1
gferris5
gferris5's Avatar
New KYB Shocks and no difference in ride?
I have a 68 long bed with original springs, (somehow I like how it sits, they are old but not too saggy...).
The ride was very smooth but very bouncy, it felt basically un-dampened. I replaced the original shocks with KYB's entry level shocks and honestly, I cannot tell ANY difference whatsoever. It still bounces like a party boat going over a wake with every turn and bump.
Am I crazy? Would a different brand/model shock be better? It seems like everyone likes KYB but this has not made me a fan... Any recs are greatly appreciated.
Have mercy, I'm recovering from my 4x4 addiction.
gferris5 is offline   Reply With Quote
Old 04-13-2022, 12:38 AM   #2
Thundarr
Thundarr's Avatar
Re: New KYB Shocks and no difference in ride?
I bought those same shocks when I first got my GMC 7 years ago.
Don't remember who, but someone here on the forum recommended the KYB Gas-A-Just. Fortunately, they are all pretty cheap, so I ditched the first set and ordered the Gas-A-Just.
The difference was amazing.
Here are the part numbers for front and rear:
KYB Gas-A-Just Shocks KG5409 & KG5416
1971 GMC C15 Sierra Grande SWB
1972 Chevy C10 Custom Deluxe LWB
2018 GMC Yukon Denali
Thundarr is offline   Reply With Quote
Old 04-13-2022, 04:08 AM   #3
Richard
The springs support the vehicle and the shocks dampen the movement. With the short stiff springs on these trucks you can have bouncy or a stiffer ride. That is the way the truck rides in stock configuration. The springs are at least 50% of the equation. A stock type replacement or cheap lift spring will ride the same way. The base level KYB's are very soft. The Gas-a-just will firm the ride up more.
Richard
Old 04-13-2022, 09:10 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Another vote for KYB Gas-A-Justs. Several years ago I replaced the mushy Monroe Gas Magnums on my K20 with KYBs. Nice firm control was especially appreciated when I had heavy loads in the bed.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 04-13-2022, 10:16 AM   #5
jimijam00
Gotta love those 52 y/o weak saggy springs that bounce.
jimijam00 is offline   Reply With Quote
Old 04-13-2022, 12:22 PM   #6
gferris5
gferris5's Avatar
Excellent, thanks for the recommendation and glad to know I'm not the only one who had the same experience!
Old 04-13-2022, 12:30 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
Did you "prime" the shocks? We used to call it "bleeding", but whatever. Try pushing a shock through its entire range of motion. If it moves easily for part of the stroke, keep that up until it resists for its entire range. If it is soft for part of the stroke, the truck's ride won't be damped enough. It usually takes 5 or so cycles through the range of motion.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 04-13-2022, 12:37 PM   #8
RustyPile
RustyPile's Avatar
You didn't say which model - 10 or 20 you have.. The C/K-20 is a 3/4 ton vehicle.. A WORK truck designed to carry loads, and soft cushy ride be damned. Empty, it'll beat your teeth out, good shocks or no. There's not much you can do to make it ride like a modern 3/4 ton vehicle.
RustyPile is offline   Reply With Quote
Old 04-13-2022, 03:35 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Good point.... I just assumed he had a 2WD truck so I didn't post any numbers.
If it helps anyone reading this, here's the KYB part numbers for a stock K20. Maybe the same for a K10 but I'm not sure so I'll shut up now.
Front #KG5408.... Rear #KG5417..... IF you have a 2.5" front lift, use rear #KG5417 in the front position also. Its extra length is just right.
- Mike -
RIP El Jay
Old 04-13-2022, 04:43 PM   #10
gferris5
gferris5's Avatar
Thanks everyone, super helpful. It is a C10. I like the 1/2 ton ride quality -- it rides great, it just needs more damping and control of the spring harmonics.
I've never heard of it. Do you reckon it would work to remove the shocks and cycle them and re-install them to recover some of their dampening? (at that point I might just spring the $200 for the gas-a-just shocks!)
FYI everyone the shocks are the Excel-G shocks (I just remembered).
Old 04-13-2022, 05:39 PM   #11
kwmech
For a gas shock yes. Most of the beginning of its life the shock was sitting on its side on a shelf for who knows how long. OR you can just keep driving the vehicle and wait for the shock to sort itself out which may take....... I find it easier (i think) to cycle them a couple of times then install them.
Old 04-13-2022, 05:51 PM   #12
Steeveedee
Who Changed This?
Steeveedee's Avatar
You have those shocks, so I'd recommend trying that first. You'll have to take the fronts off, but all you have to do is remove them from the bottom bolt and cycle the rears in place.
~Steven
Simi Valley, CA
Old 04-13-2022, 07:36 PM   #13
jimijam00
I never knew this was a thing, and I've installed over a dozen sets of shocks so far in my life. I have never had a problem with pulling shocks out of the box and putting them directly on the vehicle without this "prime" thing.
Old 04-13-2022, 11:26 PM   #14
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Same -- I have heard of it but have never done it, and never had a problem.
- Mike -
RIP El Jay
Old 04-14-2022, 12:43 AM   #15
PbFut
OP. I was recently looking for a set of shocks. I saw a set online reasonably priced that stated the rebound valving had been changed. It would improve bounce but my experience is that increased rebound makes for a stiff ride. Damn if I can find it now. Photo was a black bodied generic looking shock body in the 50-60 buck range. Sorry I can't seem to find it tonight. Might be to your liking if you can find it
Found it https://www.performanceonline.com/19...tern-DS2-Each/
PbFut is offline   Reply With Quote
Old 04-14-2022, 07:55 PM   #16
toolboxchev
Talking Re: New KYB Shocks and no difference in ride?
I put new KYB's in my truck little over 2 years ago. Made a historic difference in the way the truck rode.
Probably so as it never had it done!
toolboxchev is offline   Reply With Quote
Old 12-06-2024, 06:07 PM   #17
72k25colo
I just saw this and revived it since I'm needing new shocks on my K25. As a dealer for KYB for 12 years I love them second to none. Excels or GR-2's are KYB's softer valved shock. good for cars and those needing a cush ride. They won't get the job done on a 3/4T. For work/off road Gas a Justs all the way! Check out how much better on washboards!
72k25colo is offline   Reply With Quote
Old 12-06-2024, 09:59 PM   #18
Rick Bollinger
I put the KYB gas adjusts on front and rear along with front and rear sway bars and turned it into a new truck. Was amazing.
Rick Bollinger is offline   Reply With Quote
