Exhaust flapper
Hey guys, I have a question. I just purchased an 85 K2500 GMC with the factory 350 and noticed it has the exhaust flapper/close off to aid in warm up on the passenger side still attached.
There looks like a vacuum diaphragm that pulls the flapper however I have no hose going to it. Or is some sort of spring that loosens up when heated sort of like a choke on a carb? Which way allows the exhaust to freely flow? Pulled in or resting?
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" Last edited by j_cst_10; 04-13-2022 at 02:38 PM. |
Re: Exhaust flapper
When vacuum is applied flapper is closed, the vacuum hose usually runs from a thermal vacuum switch. No vacuum and the flapper is open so it is fine without a vacuum hose hooked up to it.
79 Chevy 2wd BIG10 350 TH400 |
Re: Exhaust flapper
Thanks for the reply. I figured it wouldn't make a whole lot of sense for it to close at zero vacuum such as a wide open throttle scenario, but wanted to make sure I wasn't missing anything.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
Re: Exhaust flapper
Don't know if this will help, this is the diagram off my 83 305 showing the EFE valve vacuum line.
| Bookmarks |
