Old 04-13-2022, 06:32 PM   #1
68C101775
Bogging/dying after being revved
Hey everyone,
In the process of attempting to get my 68c10 road worthy. 6 cylinder 250/Rochester monojet. Truck will rev up great but coming off the idle will drop super low and sometimes come back up or sometimes stall and die. I made another post about bogging and dying when braking as well not sure if they’re related. Any tips would be great I attached a pic of her.
68C101775 is offline   Reply With Quote
Old 04-13-2022, 07:04 PM   #2
geezer#99
geezer#99's Avatar
Re: Bogging/dying after being revved
Accelerator pump.
Stroke the throttle and look for a solid shot of fuel inside the carb.
Old 04-13-2022, 07:32 PM   #3
68C101775
Originally Posted by geezer#99 View Post
Accelerator pump.
Wouldn’t that cause issues actually reving up from idle and not coming down from the high rpm?
Old 04-13-2022, 07:56 PM   #4
geezer#99
geezer#99's Avatar
On second thought maybe a vacuum leak.
Carb base gasket maybe.
And another thought!
Have you done anything with the distributor?
Changed points or checked the gap or dwell?
Some distributor problems cause your running problems.
Old 04-13-2022, 08:54 PM   #5
68C101775
I just changed the rotor button, cap, wires and plugs and messed w timing. I haven’t done anything w gap or dwell but I don’t have a dwell meter. I can check the gap w feeler gauges tmrw
Old 04-14-2022, 07:58 PM   #6
toolboxchev
Get a couple of things you will use over the course of the next few years,
Compression tester
Leakdown tester
RPM Gauge
Vac gauge
dial back timing light
It will save you tons of time to get the engine diagnosed properly from the start.
Erroneous answers are just pointers to one direction or out of scope of the problem.
toolboxchev is offline   Reply With Quote
Old 04-15-2022, 09:10 AM   #7
CantPutTheSmokeBack
Sounds like both my truck and Caprice when I put new carbs on them, before rejetting. They were jetted so rich, when I would give it any throttle it would give way too much fuel and not burn through enough before coming back down. If you can, get a wideband AFR gauge. They're not cheap though. But I'll never have another vehicle with a carb and no AFR. The free version of this is of course reading plugs, but I've had and seen in others issues even when following guides to the letter.
CantPutTheSmokeBack is offline   Reply With Quote
Old 04-15-2022, 09:42 AM   #8
68C101775
I’ll look into that. Found a vacuum leak where the intake manifold met the head so I’ve got those pulled off for a new gasket. If that doesn’t solve my inconsistencies I’ll go back to the carb. Got a dwell/tach in the mail on the way so I’m hoping with that, a timing light, and vacuum gauge I can just get her consistently roadworthy while I attempt my first engine build for her.
