Rear Sway bar and loweing blocks
When i bought my truck it had lowering blocks installed. Can I still run a rear sway bar ?
Re: Rear Sway bar and loweing blocks
If you have trailing arm suspension, you already have an integrated sway bar. You see, the axle is U-bolted directly to the trailing arms. So as one tire goes up, it has to twist and flex the control arms, thereby offering a measure of sway resistance.
Your biggest bang for the buck is to replace the front bar with a 1-ton (1.25") bar.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs |
![]() Join Date: Dec 1999
Yes you can.
I would recommend you get one that goes over the frame and doesn't mount to the bottom of the trailing arms. See here: http://67-72chevytrucks.com/vboard/s...d.php?t=699495 Do not buy the CPP trash like I did. The sway bar mounts end up as the lowest point on the truck. Can't wait to see if they hit road debris and get ripped off. Also I had to modify the way they mount to the trailing arms because it's a bad design and CPP was no help. Wish I had bought this: https://nolimit.net/store/Rear-Sway-Bar-p28240717 |
