Old 04-14-2022, 11:56 AM   #1
72farmer
Leaking Durajet carburator on 79 C10
I have a 79 LWB Scottsdale with a 305 v8. My dad bought it new. The original 2 barrel Durajet 210. The threads on the carb. body are stripped. Where the filter and fuel line from pump comes in.
I bought one of them oversize self threading fitting's. It has worked about 6 months but now it is leaking and will not tighten anymore. I got to have a new carb. body or go another route. I cant find much on replacing the Durajet online.
72farmer is offline   Reply With Quote
Old 04-14-2022, 12:07 PM   #2
geezer#99
geezer#99's Avatar
Re: Leaking Durajet carburator on 79 C10
I’d try doubling up the gaskets.
https://quadrajetparts.com/dualjet-i...c-181_187.html
And I see they might be able to helicoil yours.
https://quadrajetparts.com/service-f...ion-p-356.html
Old 04-14-2022, 01:10 PM   #3
Dead Parrot
If the Durajet is otherwise working, fixing it is probably the simplest. If it has other problems on top of the leak, I would replace it. Depending on your long term plans, could replace with like carb or swap on a 4bbl manifold and carb. A 4 bbl may seem to much for a 305 but they did put Q-jets on stock 327s.
One last ditch thing to try is remove the filter, dry everything and use a batch of JBWeld or similar as 'pipe dope' when you screw the empty filter housing into the carb body one last time. You will have to make other arrangements for a filter.
Dead Parrot is offline   Reply With Quote
Old 04-14-2022, 06:18 PM   #4
cadillac_al
Most of the 305 trucks had Quadrajets anyway. I guess your choice is if you want to keep it the way Dad bought it or swap in a 4 bbl set up. Why is the intake black?
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 04-15-2022, 10:21 AM   #5
Axle
Axle's Avatar
If it where mine, remove the carb filter and seal up the threads so you don't need to put any further wear & tear on the carb threads. Put an inline filter in the rubber hose by the fuel pump.
Gas resistant sealant I've used successfully. Might take some hunting to find a local parts store that has it: https://www.permatex.com/products/ga...-liquid-16-oz/
And if you do plumbing, you might have some rectorseal it is gasoline rated and you can find it at home despot. I have not used it on any gasoline apps, but its the goto for other materials. Take your pick;
No5; https://rectorseal.com/rectorseal-no-5-group/
TruBlue: https://rectorseal.com/rectorseal-tru-blu-group/
Axle is offline   Reply With Quote
