Old 04-17-2022, 09:18 AM   #1
Peanut74
Neutral Safety Switch wiring question
We after a near catastrophe I need to get my neutral safety switch wired in. From looking at the wiring diagram I need cut the purple wire of the ignition switch. I would then reroute the circuit to the safety switch then to the ignition switch. Just want to be sure I splice into the right one.
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 04-17-2022, 10:43 AM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Neutral Safety Switch wiring question
Power goes from the ignition switch to the neutral safety switch then to the starter solenoid.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 04-17-2022, 11:44 AM   #3
Peanut74
Ok, so wire opposite of the way I was thinking of doing it.
As for which wire to cut. On the plug in the picture is it the purple wire?
Old 04-17-2022, 11:54 AM   #4
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Purple is correct. I have to do this as I have a 4sp truck and it was converted to automatic. The harnesses were not corrected.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 04-17-2022, 01:44 PM   #5
Peanut74
Thanks Smitty. Since I have to disect the wire harness I want to be sure I got the right one.
Back story
Grandson was playing in the truck. Knocked it out of gear. Normally this wasn't an issue as the drive shaft was out of it. Well this time the drive shaft was in. Went to start it and it jumped into reverse. Luckily it stalled.
Old 04-17-2022, 02:35 PM   #6
71meangreenc10
Not a problem.
Smitty
71 C30 Wrecker
Old 04-18-2022, 10:24 AM   #7
PbFut
I too had a close call on my 72 Auto this weekend. Still learning the truck, I am unsure where the safety switch is. Can someone give me a description of location and if they had a similar issue the repair they needed to perform? Seems odd a safety switch has failed. Column looks original and untouched. From the above picture, appears I'll be upside-down on the floor.
PbFut is offline   Reply With Quote
Old 04-18-2022, 10:37 AM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
On a column shift automatic, the NSS is on top of the column. Semi-typical failure repair is to put in a jumper wire. That's OK if you know about it. I personally replace the switch. My family can't deal with anything out of the ordinary on vehicles.
~Steven
Simi Valley, CA
Old 04-19-2022, 03:52 AM   #9
AllGoNoShow
When did these switches become standard? I have a 68 that is a manual an wondering if it has one, or if I should add one.
AllGoNoShow is offline   Reply With Quote
Old 04-19-2022, 05:05 PM   #10
Peanut74
Well I got my NSS in. Not a hard job just a pain trying to solder those heavy wires. Not sure if it's adjusted right as the truck is still on jackstands. That's my way of making sure it's not in gear, a 2nd time, when I start it. Currently working on finishing up the brakes. Once that's done I can test the switch and adjust it if I have to.
