Old 04-17-2022, 05:34 PM   #1
DCLefler
Front cross member
I bought a front cross member to convert my 65 SBW to power disc brakes. I can not identify what it came out of. everything looks like a mid 80s cross member except the motor mount perch's. there are free standing. A little help would be appreciated.
DCLefler is offline   Reply With Quote
Old 04-17-2022, 08:05 PM   #2
AcampoDave
AcampoDave's Avatar
Re: Front cross member
Im guessing those motor mounts were put there by a previous owner. Those nuts look newer and there appears to be unused factory mount holes. I don't really know my 80's trucks too well though.
AcampoDave is offline   Reply With Quote
Old 04-17-2022, 09:30 PM   #3
cwcarpenter98
cwcarpenter98's Avatar
I wonder if this one is out of a diesel square? I'm not sure what the difference is between the Oldsmobile diesel engine mounts vs. the regular sbc mounts. I don't believe they are big block mounts because those went to the top of the frame in the trucks
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 04-17-2022, 10:22 PM   #4
62c30
70-80's with maybe inline 6 mounts?
62c30 is offline   Reply With Quote
Old 04-18-2022, 09:45 AM   #5
SCOTI
SCOTI's Avatar
Definitely a 73-87 x-member or @ least 73-87 arms.
I've never seen a 'floating' motor-mount stanchion/tower on these trucks (C10's). All of the trucks I've seen throughout my years were anchored @ the top of the rail as well as @ the x-member (I started paying attention to this stuff in the early 80's through present). I'm betting that was driveway-built.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 04-18-2022, 11:35 AM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
They don't look original to that cross member.
66 C20 Service Truck:
Old 04-18-2022, 01:28 PM   #7
Chevy Fleetside
Chevy Fleetside's Avatar
You do know you don't need the whole cross member to do disc brakes. You can just use the spindles with your original control arms. Unless you want to upgrade front suspension to later version.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 04-26-2022, 04:04 PM   #8
DCLefler
They are original mounts. After looking further the measurement across the frame is almost 6 inches wider than a interchangeable crossmember ( 73-87). I am guessing a van or commercial truck. The thing that is odd is that it has 5on5 wheels. Weird
Old 04-26-2022, 04:27 PM   #9
SCOTI
SCOTI's Avatar
HD commercial set-ups would not have the C10 rubber bushings. They would have the earlier rubber-lined steel sleeve set-up.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-26-2022, 07:41 PM   #10
AcampoDave
AcampoDave's Avatar
My money is on "van" they are indeed wider both front and rear.
Old 05-17-2022, 10:53 AM   #11
NDM
What did the crossmember set you back? I am looking for the parts to swap my 72 Blazer to 2wd. If you do not need it would you be selling it?
NDM is offline   Reply With Quote
Old 05-17-2022, 12:22 PM   #12
DCLefler
Sorry but i returned it to the Salvage yard and exchanged it for the proper size crossmember. I paid 250 for everything including the P/S gear.
Old 05-17-2022, 01:12 PM   #13
SCOTI
SCOTI's Avatar
Glad they worked w/you on an exchange.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
